Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Yeh that was the only mod, block off bov after tune - and yes they don't bloody know what the problem is lol..
Edited by rondofj
It can still get reversion with the BOV blocked, when you shut the throttle the air built up by the turbo has to go somewhere and with no where else to go it goes backwards through the turbo to the AFM
That could also be causing and increasing the hesitation between gears
Then this.^^^^^^^^^^^^^^^
Unblock it.
Actually, at this point, going back to the first post in thread....I want to know what Ron meant by "jumps down 5 or 6 cells". By this I mean......down as in down the screen (which is an increase in load on a PFC, yes?) or down as in less load.
And, can we see photos of the BOV return location at the turbo intake please?
BOV return looks ok for the record. I doubt given the bend in the intake pipe and the location and angle of BOV return this is causing any issues.
A lot of smack being spoken about the tuner with many of you having nfi.
My bov return was on a similar angle and caused issues untill I changed it to approx 45 degree angle pointing straight at the compressor. This made a huge improvement.
Afm's are very sensitive.
The tuner talk is obviously going to happen, seeing as the car isn't running right and they can't see why or fix it. That would be extremely frustrating for Ron.
For the record you have no idea if it has been tuned well , just the same as guys that are suggesting it could be the tunes fault don't know either. The high fuel consumption certainly suggests it's not an ideal tune in the cruise areas don't you think?
I know with the GTRs when you change from rubber intake to alloy ones with AFMs still in play they tend to get reversion even if they are exactly as per factory, something to do with the ribs in the rubber pipes regulating the air speeds
AFMs are very sensitive to even very small changes and as Ben said the return should be pointed at the compressor wheel, it helps the air circulate through the turbo to the BOV and around again instead of backing up though the AFM
A blocked BOV will give the same result as a open atom BOV as the already metered air passes back through it telling the ECU it has air going into the motor as AFMs don't know which way air is flowing only how much is passing through it
You need to get someone to watch the AFM map trace as you drive and see what it does
This ^^
I think we discussed this already, about a year ago... And I gave up on it. AFM's can read up to 1 volt of reverse flow.
What I don't understand is how the tuner can't work out what's going on...
My intake again - the black rubber breather hose on left from cam cover wraps under intake pipe before curling over it to the joiner/entry, courtesy of JEM's 3rd party fabricators :Dpost-49401-14072786740475_thumb.jpg
GTSBoy yes the map tracer leaps down/south towards the higher load areas- literally jumps 5-6 cells-- r&r basically
No such thing, it jumps because the ECU is interpreting load not going into R&R
Scotty, the tuner says that at that point the ecu is dumping tons of fuel and retarding the timing like a mofo, this problem is not intermittent but constant, hence he decided the afm is ok- said to look at the entry angle of the bov return, relocating afm etc- but I doubt this would solve the issue- with Nistune and same all else this problem didnt exist- he said filters in Nistune mask the problem out- Im like really..
My cars been running rough again lately with O2 feedback off- do I disconnect the O2 plug too ?? cos the powerfc is still reading the sensor voltage and its variable volts with throttle input.
Yavuz saw it jump and thats when he was convinced theres a big problem- he said that its dumping fuel n retarding timing at that point.
Yesterday I unplugged the z32 and it wouldnt even start- just cough cough and die lol
Edited by rondofj
My intake again - the black rubber breather hose on left from cam cover wraps under intake pipe before curling over it to the joiner/entry, courtesy of JEM's 3rd party fabricators :Dattachicon.gifImageUploadedBySAU Community1407278665.866575.jpg
That hose looks like its not a good fit and the pipe even looks oval shaped?
  • Like 1
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
