Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Gareth, you have put 300k KMs on your 25, what are you doing laps of Australia or do you live in your car cause dam !!!!
I've owned my car since 2002. when i bought it it had 134,000kms on it. i've still never lifted the head off the motor and i've done all the maintainence myself....most of the problems are with the ancillary parts of the motor failing over time e.g turbo....
If you keep standard internals its well within the realm of possibility.
So you are saying it is possible with a blown 25 to build a 25/30 on the road for that price? Don't think so. Not even close.
My bet is that your highly strung 4G63 will grenade long before my 25 will! Crankwalk anyone? :woot:.. Mick O
Edited by rondofj
Lol care to place money on that Ronaldo? Dunno how its more highly strung? Im running a pound or 2 more boost than your car on Ethanol with a lower comp ratio and probably make similar to a little more power than you.
Its just a better designed more efficient engine than the old RB :)
agreed, RBs are old dinosaur tech
Where did they over engineer it?
Certainly not the oiling system....or the cooling system....or the cylinder head....or the turbo chargers......did I mention the oiling?
Stock engines weren't designed to rev at 8500 rpm for 10 secs bouncing off the limiter at double the intended boost. Do that to most engines and you will kill them.
Edited by XGTRX
Micko Atleast knows where his timing is sitting... Just saying.
  • Like 2
Yes, and I know this because I have done it. Thanks champ.
Same here. Stock bottom end untouched. All up less than 700 including oil etc for everything including retune. Took a whole week working on it a bit after work.
Not what I would call built though, as it's untouched.
But.... I know what I'm doing.... can set timing etc :)
Can't really see the point building one when a 200 buck engine does aso well!
Edited by Ben C34
  • Like 1
Sorry my bad. I assumed that going a 3L you would upgrade the supporting mods, water and oil pump, timing belt, clutch and at least a dyno tune. Obviously not the case, I apologise.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
