Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Gareth, you have put 300k KMs on your 25, what are you doing laps of Australia or do you live in your car cause dam !!!!
I've owned my car since 2002. when i bought it it had 134,000kms on it. i've still never lifted the head off the motor and i've done all the maintainence myself....most of the problems are with the ancillary parts of the motor failing over time e.g turbo....
If you keep standard internals its well within the realm of possibility.
So you are saying it is possible with a blown 25 to build a 25/30 on the road for that price? Don't think so. Not even close.
My bet is that your highly strung 4G63 will grenade long before my 25 will! Crankwalk anyone? :woot:.. Mick O
Edited by rondofj
Lol care to place money on that Ronaldo? Dunno how its more highly strung? Im running a pound or 2 more boost than your car on Ethanol with a lower comp ratio and probably make similar to a little more power than you.
Its just a better designed more efficient engine than the old RB :)
agreed, RBs are old dinosaur tech
Where did they over engineer it?
Certainly not the oiling system....or the cooling system....or the cylinder head....or the turbo chargers......did I mention the oiling?
Stock engines weren't designed to rev at 8500 rpm for 10 secs bouncing off the limiter at double the intended boost. Do that to most engines and you will kill them.
Edited by XGTRX
Micko Atleast knows where his timing is sitting... Just saying.
  • Like 2
Yes, and I know this because I have done it. Thanks champ.
Same here. Stock bottom end untouched. All up less than 700 including oil etc for everything including retune. Took a whole week working on it a bit after work.
Not what I would call built though, as it's untouched.
But.... I know what I'm doing.... can set timing etc :)
Can't really see the point building one when a 200 buck engine does aso well!
Edited by Ben C34
  • Like 1
Sorry my bad. I assumed that going a 3L you would upgrade the supporting mods, water and oil pump, timing belt, clutch and at least a dyno tune. Obviously not the case, I apologise.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
