Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Cheers for the explanation XKLABA.
Ron, I can't see how when using the plug lead method you don't get an accurate reading. That's exactly how the timing guns are designed to work.
Woot, on that flat smoky whitish face of the coil...
Yeah, that bit, directly behind that whitish stuff is the part of the coil that makes the spark and the pick up in the light will pick up the coil firing
This is right :thumbsup: I just got lazy and didn't want to do that every time i set the timing after removing the Cas, adjusting the cam gear the replacing Cas set timing taking car for drive then repeat :(
I think he meant the wire loop in the harness ?
OK just did what xklaba does - inductive pickup straight off no1 coil front face - 20-21 degrees on PFC commander AND harmonic balancer, so all good- this is the easiest n best method! Timings higher cos cars colder at 61 degrees water temp
The first time some weeks ago I didnt check the commander when setting cas to display 20 on harmonic balancer, I just assumed it would be 15 as thats what the idle always is on a hot engine, silly me didn't realize that on a slightly colder engine the commander would most likely have been displaying 20. And because 15 is the stock base timing that cemented the thought it WOULD be 15 displayed
Edited by rondofj
Dont worry, you won't understand it anyways.
Who is that cretin?
Cmon Bro, don't clog Rons thread. It's doing a fine job on its own.
If you want to have a chat do it via the PM I sent you, don't be a hero on here.
Ben
Timings done n dusted. Fuel economy with new O2 sensor = 21l/100kms, same driving pattern as usual nothing new.
Wideband with gauge on agenda, will that do on its own? Not wanting to get a datalogit etc, dont even have a laptop lolz but can borrow one. Option 2 is take to Unigroup n get an AFR log on dyno. Which is the better option?
Any other opinions on getting an afr log at the dyno vs getting own wideband with gauge?
And that intake pipe mods not happening, I've said that a few times already. For now that is
Haha. Tuner will be seeing it soon. And what do u mean by actual fault Scotty? Fault of the temp power loss during shifts? Yep the bov entry could be the fault of that..but who cares..not worth fixing somethin that accounts for barely 2% of my driving.
On a different note, see pics of my tacho/speedo combo in 5th, diff looks stock as far as I know and stock box of course. Something we spoke about once- pics to put it to rest.post-49401-14106061208116_thumb.jpgpost-49401-14106061389729_thumb.jpg
But that's what the whole topic was about! But now you know how to fix it, you don't want to fix it because now it's not a problem. Hmmmm at least you're consistent. You're funny.
Is that what the whole topic was about? Really.. Have you even read all the other problems n nigglings that have been fixed now? Now whos funny? Lol
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
