I got my genuine Nissan idler bearing bolt and this is the first thing I see.
The runout of the last thread looks pretty nasty, lots of grooves (stress risers).
Has anyone else got a new idler bearing bolt to see if it is like mine?
Maybe post up a picture?
https://www.sau.com.au/forums/topic/446413-rb-idler-bearing-bolt/
It's not a bolt that needs to be super tight so will not be a problem at all.
If it was a torque to yield bolt you might be concerned but not for an idler bolt that is only tight not stetched.
  • Like 1
Can't believe there was a thread made for this.......
You dont use the last thread
There is only about 20ish Nm of torque on the nut
I've seen worse, People re-use these without problems
Honestly. If it is worrying you that much, Just buy another one, They arent expensive
  • Like 1
I know what is wrong with the bolt, I was curious if other people had noticed the same thing.
Just because you don't use that section of the thread doesn't mean its not doing anything. Its actually doing alot more than the threads that are engaged.
Torque for that bolt is 43 - 58Nm and it is in single shear.
I am buying another one.
Some suggested reading material.
http://www.engr.sjsu.edu/youssefi/me154/notes/Bolt%20failure.pdf
http://arp-bolts.mobi/p/tech.php?page=2
Remember that the stud/nut are clamping the stationary part of the bearing
My comment about the nut not using that part of the thread was more about - your not going to make the thread any worse, then say if you ran a nut over it and damaged either the thread on the nut or stud. I'm fully aware of how forces are applied on bolts/studs
I was only saying, I can't see a major fault with the thread from the photo, maybe its the way the flash has gone off but it doesnt look that bad at all to me. And there is always chances of minor defects in a manufacturing process. And for the sake of a $2 part.......
As for your reading material, don't assume people are clueless when you dont know what they do for a living.
  • Like 1
Quite a long time back there was a spate of engine failures due to breaking of the idler bolt.
I spoke with Gary Cook regarding better quality bolts as the stocker isn't anything out of the box.
Gary had bought a selection of Nissan studs and the quality control was appalling.
Plenty of Unbrako quality to choose from but they don't fit under the cover, head is a bit too long.
Then almost overnight, no more breakages of the stock stud.
So were owners over tightening the stud or perhaps the belt, or did Nissan improve their quality control??????
The cross section there looks to be a fair bit bigger than in the next valley where the thread is fully formed, and those scratch marks dont appear to deep. So it doesn't look too scary to me, but i've never looked that closely before. :unsure:
My method of installing bolts.
Does this bolt fit? > Yes > put it in and tighten it to FT spec
> No > don't use it
Do I have another one that fits? > Yes > Use that one then
> No > ......where did I put my tap and die kit....
Edited by iruvyouskyrine
It's your bolt. If you don't like it and don't want to use it get another one.
Think you may have skipped a post there.
I am just curious to see what other peoples thoughts are.
It turns out it's to hard to show fine detail in a picture and very few people actually understand how surface finish can affect the life of something is under stress, so hopefully this thread can educate some people.
Here is another excellent article, scroll down to Surface Roughness
http://www.efunda.com/formulae/solid_mechanics/fatigue/fatigue_factor.cfm
I believe you are over thinking the whole thing. I would use it unless the picture doesn't show some horrible defect.
It looks pretty standard like marks from the machines used to roll or cut the thread
Edited by 89CAL
The threads are rolled, very poorly I might add. The finish indicates worn forming tools. I can say this due to experience in manufacturing head studs.
So, back to my original question.
Could you please post up a close up picture?
I'm not interested in anyone's opinion, that's not what I am asking for. I am asking for a picture of the threads.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
