Hey all,
Gotta a question, my R33 has had brand new genuine nissan coil packs in it. The other day it developed a miss on boost so I thought it was the plugs since they were nearing the second oil chance/10000km. I changed the spark plugs to a fresh new set, gapped to .833 and took it for a drive only to find the miss is still there. It takes effect at about 4000rpm as soon as boost is ramped up. I run an SS2 on 15psi. Low down and cruising the car is fine, just getting weak spark. It will free rev to 7000rpm without an issue. I can close the gap a little tighter but really want to avoid this.
The coil packs were brand new and about 3 years old. The car is always run with the coil pack cover removed. Would my better option be a set of spitfires or have OEM's become more affordable? Are the Spitfires improved over the standard coils? Will they last longer and eliminate the need to gap the plugs?
https://www.sau.com.au/forums/topic/446696-how-long-should-coil-packs-last/
Why are you sure is due to weak spark and not a boost leak?
I'm not, really. I assume its spark related since the symptoms are exactly the same as when one of my yellow jackets was on its way out. I have no issues building boost, its just the 4krpm barrier, it farts and carries on. I will take the whole thing apart this weekend and see if I can see any issues with the coils, I'll regap the plugs, I'll extend the spring in the coils a little more and I'll go over for boost leaks.
Can I just test from the turbo inlet all the way back or should I disconnect from the TB, block it off then test from the turbo? It was a kick in the balls to hear it miss when I took it out last week, I was really hoping it was just the plugs. I think I should isolate the intake from the engine otherwise the air will just piss out the engine.
Edited by SargeRX8
Just did a intake pressure test. Only place which started squeezing air out was the oil filler hole in the top of the engine. I could not hear any hissing anywhere else around the engine bay. I took all the plugs out, checked the gaps and put it all back together. The miss is still there on boost. Looks like I might have a dud coil. I'll be ordering another set of OEM's. Ah well.
unfortunately I don't think there's any way to tell. Bought mine on ebay for $330 and assumed fakes at that price. Compared them to my original ones and they were physically identical in every way, and arrived in nissan boxes. Mine are still working fine but who knows
Yeah my second set I just bought off eBay for the exact same price from a seller in Melbourne with relatively good reputation. He also sells Z32, not genuine, listed as aftermarket parts. The coil packs are listed as Genuine Nissan made in Japan components.
When they arrive, I'll be trying to pinpoint the faulty coil using the new ones, one by one. When I find the one causing the fault, I will dissect it and also dissect one of my original nissans which is no good and comparing the internals. Even genuine components could be prone to failure.
The only thing which would make me iffy is when sellers sell oem components, not listed as genuine and come on oem packaging.
I'm not dissatisfied with the performance of my current coils. I got a good 3 years about of them, about 45000km. The previous yellow jackets I had lasted about half a year.
Edited by SargeRX8
New plugs new coils and still cant get past 4000rpm. Ive checked for boost leaks and found nothing. Ill try again on saturday for leaks.
What else can cause this? My coil loom looks like shit. Broken clips and what not. Nothing in my car has changed. This came about all of sudden about 3 weeks ago. I dont think my coils had anything to do with it. Unless my testing has fouled my plugs which isn't likely.
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
