First post so take it easy.
I bought the mrs a series 2 33 which was pretty stock apart from slammed suspension and pod filter.
All i have done so far is a front mount intercooler.
i am getting a boost controller in the next few weeks.
What other reasonably cheap mods can i do to give it a bit more go?
https://www.sau.com.au/forums/topic/446752-r33-s2/
In a nutshell (and I'm assuming it's a GTST, not a GTR, but it's worth you mentioning these things):
Forget about the boost controller at this stage
Do a full service if you don't know the status - oil, oil filter, air filter, coolant, plugs, check wiring
Think about a timing belt replacement if you don't know how old it is
If you do the timing belt, also replace the water pump, crank & cam seals, tensioner & idler pulleys
Test for boost leaks
New fuel pump for safety - if it's still got the original one it's around 20 years old
3" Turbo back exhaust, including high-flow cat
Z32 (300ZX) or R32 ECU plus a Nistune daughter board - this will allow a tuner to modify the factory tune
R32 Wastegate actuator (10 psi vs 5psi stock)
Get it tuned by someone who knows what they are doing - 210+ RWKW and a different car to drive
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7364960
Cheers for that
It does have a 3" exhaust
front mount
and timing water pump etc have been done 60000km ago.
I was suprised drives better than a few cars i have driven lately that are less than 5 years old.
ECU is in the works as well as a tune.
The 32 wastegate actuator i take it is a stock item on the r32 and pretty easy to come by.
It is actually sounding quite cheap to do what i need.
Suspension will be the hard bit as at the moment its a bit to low and before to long i can see me or her leaving the front bar on a speed bump or something
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7364989
I would strongly suggest avoiding Nistune with an R33. There are numerous other ECU's that will plug and play such as PoweFC (older tech) through to Adaptronic, Haltech, Link.
I would consider carefully what you want from the car as careful selection of parts in the first place will save you thousands. If you want more than 200rwkw then you are into the world of aftermarket turbos and new injectors. Each change will require more tuning so take your time to figure out realistically how you will use the car and how much power is needed to achieve it.
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7365015
Cheers for that
front mount
Is this going on the timing belt change info from its Japan days or has it been done in Australia? (kms get wound off in the importation process).
Is the 3" exhaust from the turbo back or just the cat convertor back? also does it have a higher flow cat?
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7365075
If it's going to be a daily & you you don't want huge power I would stick with a Nistune. Others will tell you different, but a Nistune will do the job for you, as it does for me.
Yes - 32 wastegate actuater is stock on an R32, and is a direct replacement on an RB25Det. If you want more than 10psi you can leave the current boost solenoid installed, either in stock wiring or hot-wired to be always on higher boost. Note I haven't tried this - our solenoid has been removed.
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7365195
There's a couple of points relating to the above post that need clarifying though.
If you use an R32 ECU to do Nistune then you don't get working VCT unless you install a separate way to switch it in and out. if you use a Z32 ECU for Nistune then a few other things don't work as well as they should. You need a decent tuner who has done these R33 Nistune jobs before to make it less painful.
If you use an R32 ECU then the stock boost solenoid cannot be controlled, because the R32 doesn't even have one.
R32 10psi actuators are not exactly lying around in piles, because every stock turbo R33 owner wants one.
https://www.sau.com.au/forums/topic/446752-r33-s2/#findComment-7365201
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
