I can't get past the "only 15,000km on them" - I have chewed out tyres in 15,000km. I think you would be hard put to say they were not fit for purpose having done 15,000km.
Well if there's enough tread left for another 15,000 kms but sidewalls start cracking, are they fit for purpose? Should tyres last for more than 18 months in normal use? I guess we'll never find out.
These Goodyears are fairly hard compound and people normally get a lot of km's out of a set.
Wear on the tread is fine, cracks/tears in the sidewall are a different thing entirely.
Don't buy those tyres lol. Plenty of other tyres on the market.
32 psi won't do that damage so that's a load of shit. if you had 10psi then yeah it's plausible then.
I had a flat (twice) on one tyre, drove around for a few (10) km, pumped them up, kept driving. Bigger sidewall than yours but no damage, they were cheap Nankangs as well.
If it was 25psi or under, yes under inflated but 32psi is BS. I would go to the manufacture and provide a copy of the invoice.
For example if you were using them on the track, and wanted 38 psi hot temps, you would be starting at around 32 psi cold depending on track, track temps, speed/driving style.
For my daily I always check the depth of tread on the outside of the tyre compared to middle, then adjust the pressure until the wear is even, and then every 6 months rotate the fronts to the rears. If the middle has less tread depth than the outside, the tyre is over inflated. If the outside has less, the tyre is under inflated. If one edge is wearing down more than the other edge then you have an alignment/ camber issue.
32 psi is for driving around town soaking up bumps :P. Pump that shit up to 38-40 psi.
I used to run 36 all round, dropped to 33 in the front, couldn't stand the noise from cracks in the roads on the direzza Z1's. I must be getting old...
Edited by sucram
Interesting. So my warranty claim was denied due to the 'low pressure' and 'non-standard camber', I wonder if I could refer this issue to anybody else? Manufacturer? I obviously don't have the damaged tyres anymore so it's getting a bit complicated..
Sorry for locating this thread belatedly.
When I had 2 cracked 3 yr old Nankangs on a Prelude some years ago, I rang around to find out what company was the Aussie distributor of Nankangs. So Blaire Tyres kept one offending tyre and placed a submission on my behalf. Within a week Nankang replaced the whole set despite 40% wear on the existing ones.
A Goodyear distributor with clout could have been your best friend, and lots of goodwill could be had. The distributor would have lost nothing except a bit of time. That's all!
  • Like 1
Thanks heaps Terry. I haven't been able to get distributor's details from the vendor but perhaps I could try Goodyear directly. Might give them a call.
  • 1 year later...
Thread revival – I was just under the car then and I think I can see a couple of cracks appearing again on the inner sidewall of the front left tyre. WTH?!
They are small and only visible in the bottom part where the tyre is bulging under the weight of the car. However if the previous set is anything to go by, there will be more cracks soon :(
These tyres have been religiously run at 38 PSI for about 15 months and just 12,000 kms, and rotated a couple of times. Not daily driven and only occasional spirited driving. They are 3213 manufacture and made in Germany.
I don't get it. Could it be something mechanical after all?
...then again, I was doing some more research and found all these:
Each has photos of various Goodyear F1's cracked in a very similar fashion to mine. I just can't believe I would have two faulty sets in a row.
Design flaw? Thoughts?
with all those bad reviews and posts why persist in buying those tyres? For the money and reduced stress level I personally would get either Nitto INVO or Bridgestone Potenza RE003
  • Like 1
The consumer law is strong - push hard and use it. Expect to be bullshitted and pushed back against. Get all your monies back. Boycott Goodyear when buying tyres. Get on with your life.
  • 2 months later...
Quick update on this, I just received a set of replacement tyres (Kumho KU36's) from the retailer and the second set of Goodyears is being returned to them for inspection.
Just in case anyone lands here googling for Goodyear F1 Asymmetric 2 inner sidewall cracking, here's the notes that sent back to the retailer:
Here's some quick notes on the Goodyear F1 Asymmetric 2's I ran for when you discuss this with your distributor:
  • First set was mounted in Jan 2013 and removed in Aug 2014. These were on the car for 15,000 kms, run at 32psi. At this point they had developed cracks on 3-4 of the tyres on the inner sidewall.
  • Second set (3213 manufacture) was mounted in Aug 2014 and removed in March 2016. These were on the car for 14,800 kms, run precisely at 38psi as per your recommendation. I found several cracks on one of the tyres back in December 2015, again on the inner sidewall.
  • The car has always had a solid alignment settings and there wasn't excessive camber wear on either set. Also both sets of tyres had recent manufacture dates so that shouldn't be the issue.
My best guess is that it's a manufacturing flaw e.g. faulty compound that results in inner sidewall failure under certain circumstances. As mentioned before, there are photos of various Goodyear F1's cracked in a very similar fashion to mine on several forums:
I never got any refund for the first set and had to fight real hard for the second one despite the identical symptoms ... I can assure you that I won't be buying Goodyears again anytime soon.
  • Like 2
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
