Would be better with injector duty cycle but a great idea.
I did some tricky wiring and used a voltage booster in my car.
Gives me three speeds - 10v, 14v, 16.5v
Edited by The Mafia
Apparently you can adjust the speed as low as you like to slow the fuel pump down but still keeping it's factory 12 volt supply but just pulsing it.
And the trigger to speed up the pump can be rpm or tps or another trigger.
Edited by mr skidz
My old man and cousin run the Aeromotive unit. It's very sensitive to voltage but works well. They run there's off the rpm signal.
sweet, did they buy it locally or online I don't think you could find one off the shelf in Australia.
Perfect fix really for massive fuel systems uses dailies
I was planning the same a few month ago.
A tuner in the know mentioned they were experiencing issue maintaining a solid even fuel pressure with it.
Consensus seems to be that you will need to run a fuel pressure damper to absorb the spikes in pressure.
  • Like 1
wasn't that from using hard fuel lines and massive injectors over 2000cc
Worst case scenario it spikes a touch, it won't matter touch of extra juice it'll be hardly measurable.
extra safety more cooling from extra fueling . ;)
Edited by mr skidz
You can get ones that fit into the fuel line, however the stock S2000 ones are cheap and reliable and i like the idea of it being right next to the injectors where the issue comes from rather than further back down the line.
I'm hearing ya, but if part of the issue is from a big pump being pulsed by a speed controller than you'd want to rectify any irregularities prior to feeding the rail I would have thought?
If the issue is in the rail only then it must be fitted to the rail.
Not sure on how these dampeners are designed, but would they possibly be able to absorb some of the rail pressure once on boost thus affecting the total amount of rail pressure to feed the injectors correctly ?
May sound dumb. But I always thought the fpr regulated flow and pressure before the injectors. While the damper was on the return, making sure there is also fuel pressure while damping flow for an even rate flow back to the tank.
Some blokes have had problems with hard starting and the damper open which causes the fuel rail to run dry.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
