Hello
I learned about 550cc injectors made by a comapny called Deatschwerks. I tried finding info about them on the web and cant find many reviews. I have read that people use them but no one has really put up a review about them.
Does anyone know if they are good injectors for the rb20 or should I stick with Nismo, Sard, or Tomei?
Edited by yoshiii335
https://www.sau.com.au/forums/topic/447036-deatschwerks-injectors-any-good/
I got the 444 from them. The flowchart that came with mine said they're matched around 458cc.
Really noisy, the idle is a little more erratic than with the standard ones but nothing to worry about, AFR are stable on idle, cold start or hot start are as good as standard.
No problem so far with 10 000 km on them on P98.
The only downside is the noise, if I had a quieter exhaust the only thing I could hear would be them.
Double check the latency, I chose the 444cc because of it, the 555cc latency is almost two times longer from memory, and I didn't really need much more on P98 anyway.
On E85 I would buy the 650cc directly.
They come with adapter plug so they're really drop in.
Just excite them with a battery before installing them. I had to excite one directly from the battery to get it to open. Then it worked like a charm.
I purchased mine directly from their site.
Really? Really?
Their sidefeeds are as good as water pistols, similar to Five-O Motorsport Garden hoses.
Since its a RB20 I would just go EV14 or IDs if you have the cash to burn.
Im using their 700cc. Noise is about the same as stock GTR. They are a touch fluffy at idle, but a
power fc idle reset got rid of most of it. Pretty common on any aftermarket injector larger then stock.
I am of the opinion that they over rate their injectors
I have their pump as well and that has been tested and around 10% over rated- although they might test with no lines, I tested in the car. Pretty stupid to rate a pump without lines
Maybe alter the search parameters to "hydrolock, Deutschwerks" and you should get some hits.
Same goes with Five-O Motorsport... I made the mistake of buying a set, recently just spent a kidney new injectors.
However being a RB20DET, and with your power goal in mind.. Stock 444cc GT-R injectors would be tits.. drop in, wire up resistor pack, rescale and off you go
I have a set of Deatschwerks 550s in my car now - have had them for about 5 years and they seem ok. However I believe they are just "remanufactured" Nismos or something and when I upgrade I will be getting IDs or Bosch or whatever they are.
DW, Five-O, ANSU, all they do is get a JECS injector and grind off the 4x hole tip which helps with the spray pattern. They then carefully enlarge the remaining single hole to increase overall flow.
I've had a look at both side feeds, and I actually own a set of Five-O and how they're produced are identical... If you look carefully you can see grind marks.... it's sad.
I have them and a pump in my old rb20 in the 32.
They seem fine, im running an rb25 turbo at 14psi and Nistune as well.
182.8 kw safe (a little rich) tune.
The best thing about them is the ease of install, they just go in like Nissan parts, no fking around.
You wont need to worry about correct resistance like if you get gtr injectors.
You get a test flow chart and spec sheet for your tuner.
So... cheap, maybe crap quality like others have said, but ok for small goals, and very easy to install.
It all comes down to the old questions of your goals and budget.
Soo much miss information here.
DW are not jecs not even remotley close. They are bosch.
They do not have re-drilled single holes and do provide a accurate spray pattern.
However this may be true with other brands mentioned.
My Dw have been perfect so far.
I had no difficulty installing.
Tuner had no probs what so ever, neither has running idle through to Wot.
Jecs left , Dw right.... ahh bit more than a hory regrind n drill hah
please read what I wrote properly dude.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
