Hello
I learned about 550cc injectors made by a comapny called Deatschwerks. I tried finding info about them on the web and cant find many reviews. I have read that people use them but no one has really put up a review about them.
Does anyone know if they are good injectors for the rb20 or should I stick with Nismo, Sard, or Tomei?
Edited by yoshiii335
https://www.sau.com.au/forums/topic/447036-deatschwerks-injectors-any-good/
I got the 444 from them. The flowchart that came with mine said they're matched around 458cc.
Really noisy, the idle is a little more erratic than with the standard ones but nothing to worry about, AFR are stable on idle, cold start or hot start are as good as standard.
No problem so far with 10 000 km on them on P98.
The only downside is the noise, if I had a quieter exhaust the only thing I could hear would be them.
Double check the latency, I chose the 444cc because of it, the 555cc latency is almost two times longer from memory, and I didn't really need much more on P98 anyway.
On E85 I would buy the 650cc directly.
They come with adapter plug so they're really drop in.
Just excite them with a battery before installing them. I had to excite one directly from the battery to get it to open. Then it worked like a charm.
I purchased mine directly from their site.
Really? Really?
Their sidefeeds are as good as water pistols, similar to Five-O Motorsport Garden hoses.
Since its a RB20 I would just go EV14 or IDs if you have the cash to burn.
Im using their 700cc. Noise is about the same as stock GTR. They are a touch fluffy at idle, but a
power fc idle reset got rid of most of it. Pretty common on any aftermarket injector larger then stock.
I am of the opinion that they over rate their injectors
I have their pump as well and that has been tested and around 10% over rated- although they might test with no lines, I tested in the car. Pretty stupid to rate a pump without lines
Maybe alter the search parameters to "hydrolock, Deutschwerks" and you should get some hits.
Same goes with Five-O Motorsport... I made the mistake of buying a set, recently just spent a kidney new injectors.
However being a RB20DET, and with your power goal in mind.. Stock 444cc GT-R injectors would be tits.. drop in, wire up resistor pack, rescale and off you go
I have a set of Deatschwerks 550s in my car now - have had them for about 5 years and they seem ok. However I believe they are just "remanufactured" Nismos or something and when I upgrade I will be getting IDs or Bosch or whatever they are.
DW, Five-O, ANSU, all they do is get a JECS injector and grind off the 4x hole tip which helps with the spray pattern. They then carefully enlarge the remaining single hole to increase overall flow.
I've had a look at both side feeds, and I actually own a set of Five-O and how they're produced are identical... If you look carefully you can see grind marks.... it's sad.
I have them and a pump in my old rb20 in the 32.
They seem fine, im running an rb25 turbo at 14psi and Nistune as well.
182.8 kw safe (a little rich) tune.
The best thing about them is the ease of install, they just go in like Nissan parts, no fking around.
You wont need to worry about correct resistance like if you get gtr injectors.
You get a test flow chart and spec sheet for your tuner.
So... cheap, maybe crap quality like others have said, but ok for small goals, and very easy to install.
It all comes down to the old questions of your goals and budget.
Soo much miss information here.
DW are not jecs not even remotley close. They are bosch.
They do not have re-drilled single holes and do provide a accurate spray pattern.
However this may be true with other brands mentioned.
My Dw have been perfect so far.
I had no difficulty installing.
Tuner had no probs what so ever, neither has running idle through to Wot.
Jecs left , Dw right.... ahh bit more than a hory regrind n drill hah
please read what I wrote properly dude.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
