I'm after some infomation, my car was tuned on caltex eflex, will I be able to use united e85 in my car if I ever wanted to, if I was around no eflex, and would it drive and perform as normal? I know caltex say the E% varies from 70-85 and they change it to suit the Seasons of the year, and united % is gaurnteed more, would the difference in e% change the way it performes?
https://www.sau.com.au/forums/topic/447351-running-on-e85-if-tuned-on-flex/
There is no e85 close by, probaly about 30-40 minutes away, but there is eflex one 10 minutes from my house, thats more the reason behind it. Only asking coz there seems to be more and united coming up around the place
I do have flex fuel sensor sniffer what ever you want to call it, the ecu has dual maps from 98 and eflex, so can't use either of them with what ever in the tank, just wasn't sure about e85 because it wasn't tuned on that
What do you mean on how it was tuned? With the fuel maps etc?
Whether the tuner has left left some leeway so that if you do put e85 from e70 and you run half a point leaner it doesnt matter but if it was tuned to its max and now you suddenly run it a point leaner it will affect you. Do you know what your A/F ratio was on the e70 tune?
Oh yer true, umm don't know of the top of my head but I'm thinking that there is leeway there.
It also depends on how Eflex is in the tank and how much E85 you put in, empty tank then fill to top will change the E% more then half tank adding 20l
I don't get this, cause the only way this would be plausible is if you emptied the tank to change from one to the other, contact your tuner and ask if he has setup a flex tune
If tuned for E70 and had to use E85 it's simple to toss ULP in to make it E70 . Its a 15% difference you can work out based on an almost 60L tank . Works out to 2.25L of petrol to every 1/4 tank so 2.25 / 4.5 / 6.75 and 9 litres . I'm sure 3 5 7 and 9 would work fine and if you have a wideband wired it would compensate enough for normal road use .
Just don't bugger it up watching the dollars instead of the litres or carry a clean dry 10L container in the boot .
A .
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
