Just a suggestion on the rims as a cheap alternative, what about a 15 steel band to what ever width you desire and use a ford steel rim centre, that way you can weld the centre to band at what ever set you want.
  • 1 month later...
Going to need more injector than what I first thought so I've got six Precision 225s and six more Precision 550s coming for it. They hurt the back pocket but they're worth it and a proven combination with methanol.
  • Like 1
So thats about 8200ccs per cylinder if my maths is close. Geez thats alot of fuel. Go hard or go home!!!
Did i miss what size turbo your running?
It's a Precision Gen-2 8891. Rated around about 1600hp. I'm looking for about 1200-1250 from it. If it makes anything like 1000kW I'll be rapt.
  • 4 weeks later...
Ross balancer, triggers, oil pump, block-offs, brackets, drives, pulleys and more arrived today to go with the Ross billet sump pan from earlier.
It all looks amazing. Can't wait to bolt it up.
  • Like 1
I have this 2nd hand Peterson dry sump tank of which I don't have any use for anymore if you are interested in purchasing it mate. Just needs a clean up and it's ready to go.
Make a cruisey offer and it's yours mate. Sorry about the sideways pics,,,my puter is not behaving.
Cheers
Neil.
Hey mate after looking at their website it looks like this one, so 3 Gals. It's a bit dirty and has the usual scratches that would polishout. The 3 straps don't have the factory bolts but thats an easy fix.
3 Gallon - 16” tall x 9” dia.
08-0009 3 Gallon Single scavenge inlet, -12 AN Female Fittings.
08-0010 3 Gallon Dual scavenge inlet, -12 An Female Fittings.
Cheers
Neil.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
