i just bought r33 recently, and i dont trust the previous owner..
car is bone stock..
i just change all of the oil recently. engine, tranny, diff..
i use MT90 for tranny..
the problem its sometime grinding when i shift into 3rd gear, and sometime into 4th gear, but only happens on high rpm. it annoys me so much.
and when i change my tranny oil, i found some metal filings on the magnet plug but not much.
its shifting normal on low rpm..
is it bad synchros or worn out clutch?
those issue happens just before i change my tranny fluid.
if its bad synchros where is the recommended place in sydney and how much in total?
because its a hard job, if its clutch i can do it my self.
thank you.
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/
I'd try some redline lightweight in it first. Having pulled a 25 gearbox apart, they are fairly labour intensive. I had a few shift problems and redline seemed to help, would be much cheaper then a box rebuild and it might work. For $100 or so, its worth a go
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7390973
The teflon can break down after a while and clag up the syncro's making them worse. I only use the lightweight shockproof in diffs and (evo) transfer cases for that reason.
I would be running fresh light gearbox oil, as someone may have just filled it on thick oil. They need to be able to spin up freely to mesh at those revs. You could try Dextron3 too before shelling out for a build...
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7390988
i havent try that surfs blood thingy. wanna try it, but i just change my oil.. huh..
btw piggaz i call them recently, they charge me 1700 for labor excl. parts.. damn expensive.. but the gearbox still attach on the car, if not idk..
i can remove the box and send to them but i cant reinstall it.. dont know how to lift it, kinda super heavy.. lack of tools..
any reasonable suggestion for rebuilding?
1700 excl. parts, better i buy rebuild second hand one..
Edited by thebuuuuu
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7391256
I've had the same issues and redline lightweight shockproof ( surfs blood) made them go away. Might not be a long time fix but, mine was fine for couple years after that.
If you really want to rebuild try Competition gearboxes
Pretty sure my syncros are screwed too. I put in Redline Lightweight Shockproof and it still grinds a little at first but once it's all warmed up it shifts fine. I just double clutch till it's up to temp.
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7391601
By the way....I love threads like these. The synchros in my gearbox are absolutely thrashed. So badly that when it was first installed it would not engage any gear with the engine running until we swapped out the normal (new) oil for smurf jizz. It got better as it was driven, but the synchros are still thrashed.
And I NEVER get a crunch on a gear change unless I've made a massive fuctercluck** of it. All you have to do is know how to change gear to avoid the crunch.
**fustercluck - when you lose all muscular coordination and make a gearchange that a recently raped chicken could have done a better job of.
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7391896
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
