Okay so sorry it's been so long.
I had an old post from a few months ago explaining my issues with my rb25 not holding boost to redline. I can't find it anymore so I have to start a new one.
Problem is it hits full boost then drops of to 11/12
Psi by the end of the rpm. Originally it was thought there were leaks and the rear housing was to small (.63)
So fixed the boost leaks! And slapped a brand new gt3076r .86 rear on
And I still have the same problem. I thought maybe the boost controller was doing it.. So wile on the dyno we adjusted the spring to 16psi and ran no boost controller and the result is the same! With no boost controller it still drops passed the waste gate spring pressure?
I give up! Anyone had this problem?
Mods
Gt3076 .86 high mount (genuine)
Stainless high mount
Pro boost wastegate 50mm
880cc injectors
Greddy plenum
Intercooler
Blitz duel solenoid boost controller
Microtech lt12s
Hey mate, this is by no means abnormal.
What boost controller were you using?
An electronic boost controller will have an option to hold boost after it peaks.
I use a GFB ge-force 2 and the setting is called sensitivity or SENS. it works flawlessly, I could hold 20psi to redline if I wanted. I think it was about $280 from MRT in Sydney on special
Just had a look at pro boost. I would be getting g a decent gate on there asap. That pro boost one doesn't inspire much confidence.
Edited by Ben C34
The stainless manifold seems to be build well. That's not saying it's not the
Problem. The wastegate port comes from both sides of the manifold then joins to 1 pipe.
The wastegate could be the issue. I only used it because a Friend had one on his vl making 500hp and seemed to work well.
Maybe the wastegate is 2 big?
As for the boost controller I'm not clear on its operation as the tuner set it up this is the model controler
The wastegate is bigger than you need but that shoudn't be the problem -its how well it works. In my opinion its essential that everyone learns how their wastegate and boost controller works. I must say I am a slow learner and it took me a fair while but often everyone will assume that someone else knows what they are doing or has set everything up right. Do a lot of Googling and find out just how your boost controller works and how it should be set up so that you can eliminate problems.
  • Like 1
Thanks for your help, iv tried looking up my issues and if I could bring up my old post from early this year you would see all the things iv tried now to hold boost. Iv hit a dead end. The only thing left sounds like new exhaust manifold and wastegate. I would have thought my sbc boost controller would be able to make it hold. But even if the gate is set to
16 pound the boost drops below that.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
