I had a workshop look over the car to inspect a clunk in the driveline as described here.
Apparently it's a combination of the following:
  • Shot diff bushes (upper & lower)
  • Worn tie rod ends
  • Worn ball joints
  • HICAS - needs a lock bar
Apparently the diff bushes is a subframe out job, is this right? I also read that it's a prick of a thing to do in an R33, is it the same for R34's?
Is there any hope to do this at home or too hard basket? I've replaced a few of metal sleeved factory bushes before and getting them out sucks bigtime :/
If it's a workshop thing, what's the approximate labour?
Should I do subframe bushes at the same time? Apparently there's a whole fruit platter you can chuck in there, no idea what them pineapples do...
Yes u should def do subframe bushes while subframe is out, If u end up removing it. Tierod ends on rear aren't a moving part and nothing on them to wear, so would assume they mean the hicas balljoints in the knuckle. The front 2diff bushes are cheap for urethane ones & are piece o piss to do, would do that first before ripping out subframe.
  • Like 1
Thanks guys. Do I have it right that the front bushes are pressed onto the diff, and the rear ones are in the subframe?
The front bushes definitely look easier to do, provided that one can get the OEM ones out (steel sleeves suck)..
Stopped being lazy and had a look, this is indeed the case.
Hey has anyone used a 'bush puller' tool that would allow removing the rear bushes on the car, without dropping the subframe?
Something that pulls out the steel sleeve too so that you don't have to resort to the hack saw method?
I'm thinking something along these lines:
or
Cheaper to just buy a bit of threaded bar, some nuts and washers to suit and just use a socket that is the right size to fit on the outside of the Bush without hitting the frame etc
Don't bother, threaded puller tools have specially hardened threads. A regular piece of threaded rod will strip before a pressed in shell gives way.
Well I dunno, get a long high tensile bolt and try it then?
Probably cost $20 max at a local bolt shop for 1 bolt, 1 nut, 3 or so washers
It was just an idea, save going and spending $100 on a puller kit to pull out a few bushes
Thanks guys.
What I'm really trying to save is hundreds worth of labour that it would cost to pull out both the diff and the subframe. If there's a tool or technique to get the upper bushes and steel sleeves out with the subframe still in the car that'd be ace, as I might be able to do it myself.
I took some photos of the four bushes, the upper ones are in a pretty tight spot but once the diff is out there might just be enough space out front to fit a puller tool in.
Also you can kind of see the steel sleeves in pics 3 and 4.
Overview
1.
2.
3.
4.
4. (front side)
My front ones came out easily and I got the rears out by cutting them with an air hacksaw then knocking them out. Is cut through the rubber and just enough of the steel to split it in 2 halves without damaging the subframe
I just let the diff hang down. Didnt even remove it fully so I didn't have to take the exhaust off
  • Like 1
Awesome, great to hear it can be done! Which bushes did you end up putting in? I'm having a look on fleabay and the rear bushes seem a bit tricky to find...
Yeah I've looked at SPF and Whiteline so far too, looks like there's a couple of different types for both upper and lower diff bushes so happy to take recommendations.
With HICAS, it looks like there's a couple of ways to approach it:
  • Typical HICAS lock bar that retains OEM steering rack ends and ball joints
  • HICAS eliminator kit that removes HICAS completely and replaces all OEM items
The eliminator kit is more exxy but my ball joints are worn and if you factor them in it's pretty much even - so I'm guessing I'm better off going with this option?
Are there any downsides to the eliminator kit over lock bar? I'm guessing either option will throw up HICAS warning light in the dash?
Eliminator kit is the only sensible option.
Unless you take the even more sensible but massive option of replacing the entire rear subframe with a non-HICAS unit like I did. Best way, but a lot of work. But if the subframe is coming out to do bushes anyway......
Thanks again.
I'm just reading up on how to remove the ball joints and it sounds like a complete PITA. I think I'd rather take it to the shop if I have to pull the uprights or the subframe out, way too much work... Apparently someone has used a puller like this for the ball joints, not sure where to find one though:
8105223.jpg?_v=5a94e708-b43a-47fc-b9d2-5
Im not sure about HICAS ones, but the regular ball joints in the lower control arms are quite easy even with a 6 ton press. You just need the right bits of scrap metal pipe to press the body of the ball joint out (not the moving pin), while bracing the arms.
Theres no doubt what you're planning is a lot of work, so make sure to get reliable quotes. You might reconsider taking it to a workshop when you get the quote, even if it is a lot of work.
Also make sure to read the instructions for whatever bushes you're using. Some may require you to leave the metal shell inside the subframe, so that may work to your advantage.
  • Like 1
Apparently on the 300ZX the HICAS ball joint can be done using a Pitman Puller Arm similar to what I posted above: How to install Hicas ball joint with out a press
I'll need to measure the arm to see if I can find a right sized puller.
I also found this 26pc Press & Pull Sleeve Kit from Radum that might work for the upper diff bushings in the subframe:
Bushing options for the diff below. There doesn't seem to be much difference between the lower (front) ones, however the upper (rear) ones from SuperPro are quite different to the other two - which ones are better?
Lower bushing (diff front side)
SuperPro SPF2637K $60.50 (via Kudos)
Whiteline W93047Diff $58.85
Nolathane 49161 $69.99 (eBay)
Upper bushing (diff rear side)
SuperPro SPF3775K $ ???
Instructions
Whiteline KDT913Diff $161.70
Instructions
Nolathane 49162 $138.88
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
