I have R33 S2 GTST with Vipec ECU which i believe is the same as a Link G4.
I have a Innovate LC2 wideband with gauge and need to know where the Brown wire goes.
- i read it goes to AN Volt input (any free ones) but which one ???
There is ECU Expansion 2 - 5V "An Volt 2" but you need the XS Vipec Loom , is there any other wire that can be used?
I also have a MAC/Vipec 3 port Boost solenoid that has 2 wires (one for 12V switched) and one for DPO / PWM Output... Where is to be wired to ?
http://www.vi-pec.com/techdata/diagrams/boost-control-solenoid-diagrams
Says take the wire to Aux X - where is the AUS X? which spare wire can be used as "X"...
Thanks everyone...
In theory you can use the wires for the stock boost solenoid for the Mac valve but in fact (and I didn't install my Link) I have the optional extra loom for my boost, air temp meter and GM MAP sensor.
If you go to the Link website
http://www.linkecu.com/
you will find pinouts for your ecu although if you didn't install it you may not know which inputs/outputs have been used and which are free.
The boost solenoid can be hooked into the standard wiring for the boost solenoid. It's not polarity sensitive so can be hooked up either way.
The wideband can be hooked into the standard signal wire for the stock narrowband sensor. I hooked mine up at the ECU plug.
If you download the Vipec tuning software (VTS I think it's called) and go into the help section there is quite a bit of wiring information.
ok i should mention it has a custom GTX35R turbo so the entire stock plenum, air intake, actuator, boost solenoid is not there anymore at all.
Looking at page 21 you see what the outputs are for
http://www.vi-pec.com/techdata/ecu-manuals-v-series/vi-pec-nissangts-gtr-plugin.pdf#
then page 23 you can see the pin layout of ecu.
So i use AN Volt 2 for wideband (but i need the XS connector for get to it as its a expansion plug not an ecu wire as such)
but the boost solenoid. What Aux is free? i have none used on the ecu, nothing has been spliced in or connected at all.
but all wires are used...
Page 12.
The expansion cable that you can buy and plug into the inside of the ecu has;
Gnd = Sensor Ground Only
+5V Out = Low Current +5V Supply
DI5 = Digital Input
DI6 = Digital Input
An Volt 8 = Analog 0-5V input (wideband) or
An Volt 2 = Analog 0-5V input (wideband)
An Temp 3 = Temperature sensor input
An Temp 4 = Temperature sensor input
but where does boost go???
Thanks
Look in the Vipec tuning software help file! I just told you this
It tells you AUX 1 = AC clutch
And so on. So seen as you don't need the stock o2 sensor you use the signal for it to hook your wideband analog voltage into
The boost solenoid is the same. The R33's have an electronic boost control valve standard to go from 5 psi to 7 psi at whatever RPM. So use those 2 wires into your MAC valve. Doesnt matter which way around the wires are as the MAC valve is not polarity sensitive.
Pretty much everything I said in the last post
I have the XS connector but it's only hooked up to my external MAP sensor, a switch in the cab and intake air temp sensor.
  • Like 1
Sorry i miss understood. Thanks for your help, i dont have the computer connector cable so have not got the software. I will download it now and see if it will allow me to open it up without connecting to ecu.
the page 21 in manual says Aux 1 is VTC solenoid which is wire 106.
The stock 02 sensor you say for the wideband, is called "Oxygen Signal Front" which is An volt 6 and wire 29 <--- so i connect the brown wire from Innovate to this then to confirm ?
The boost solenoid i dont know where the electronic boost control valve is as it was removed, looking at page 21 and 23 is it "WG solenoid" Aux 8 - wire 25 <--- one of the MAC wires goes to this ?
Thanks again and sorry to triple answer, just want to splice into correct wire !
There should be a 2 pin plug somewhere near the AFM plug. Pretty sure it's in the same loom as the AFM plug.
If I had my wiring diagram I could confirm and if you had the cable you could test it. If you can get a hold of the cable it would be great
My Link G4 came with the USB cable so I figured the VIPEC would too
It has a serial connector requiring and $80 cable to usb or something :/
According to this
http://www.paulr33.com/diagrams/r33-rb25-wiring.jpg
(here is a larger more clearer image http://forums.hybridz.org/topic/102105-rb25-miss-at-idle-a-little-through-the-rev-band/)
is it is indeed pin 25 so that goes to the MAC boost solenoid wire.
I asked godzillamotorsports and they suggested getting the XS expansion cable to do the wideband rather than the o2 sensor lead. not sure why but ok.
And any suggestions on wastegate plumbing ?
Two waste gate side ports T'eed' together and then another T joins the plenum port (greddy) to the wastegates but they vent to atmosphere, the boost solenoid is just a T.. thats how i brought it... thus me wanting a MAC solenoid. Do i need top ports to be installed for the wastegate and how should they all go into the MAC solenoid?
Thanks so much !!
How much boost are you trying to run? If the wastegate springs are close to the desired boost level you will be fine just controlling the lower port to open the gate. If you want to hold twice what the spring is rated to, you will need to direct boost to the top port, to help hold the gate shut as the exhaust manifold pressure rises.
I use a 5 port MAC to control both ports directly, you can also use 4 port MAC valves in the same way. If you want to use the 3 port MAC you won't be able to bleed the boost off one port or the other, depending how you set it up.
Turbosmart have a good tutorial on it...
http://www.turbosmart.com.au/wp-content/uploads/2012/06/TS-0505-1001_Compgate40_MAY_12_rev_2.pdf
Thanks Scotty
i have the 3 port mac, boost is at 20 now so dont need additional spring psi
what way do you suggest from that info?
Just leave the upper port/s venting, and run the hose from the cooler pipe, through the MAC, then T'd to the lower port/s. If you have issues holding boost you may need to replace the lower section of the MAC to the 4 or 5 port for the next tune. (the coils halves are usually similar and you can buy parts for them locally.)
Thanks, awesome document btw.
Since the springs are already strong ill use Single port connection Method, that what you referring to ?
Top ports of wastegates vent to atmosphere
Port 1 of solenoid vent to atmosphere
Port 2 of solenoid to bottom ports of wastegates
Port 3 of solenoid to Pressure only source (turbo/cooler pipe?)
wire mac valve to std boost controller wiring and same with 02 sensor. Run brown wire to 02 signal wire and and just select innovate in drop down menu instead of oem narrowband.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
