Hey Guys from the other side of the Globe :-D
i`m not as new as it seems but it`s my first post / thread and post here and i hope you`ll not beat me for that question... Well, i own a ECR33 since 2010 and i`m on the way to build my second engine for over 500hp. I`m hunting for 500-550 engine hp so i guess thats about 305-315rwkw... prerequisite for my build is..
- IT MUST BE BOTTOM (LOW) MOUNTED prefered IWG and Journal Bearing in case of wear ^^
I`ve found like a lot people here the maker KINUGAWA and it seems they have good stuff especially these are build on MHI chargers or Garrett...
So i thought the right Turbo could be a TD06H 25G because it`s +- the same size (wheels) as GT3076R... But will the TD06 fit in with aftermarket or OEM low mount manifold??
PLEASE ADVISE ME THE RIGHT TUBBY!^^
Edited by DK-Spec
https://www.sau.com.au/forums/topic/449047-biggest-low-mount-turbo-on-rb25det/
Yes any TD06/GT30 and equivalent precision etc can be low mounted without too much hassle. Will need a T3 manifold spacer for front housing clearance on the exhaust manifold though. Cracking 300kw at the rear wheels low mounted with a reasonable stealthy setup is no issue nowdays.
I have heard that all Kinugawa turbos have issues with internal gate setup. I have experienced it twice firsthand so dont really want to recommend them. Externally gated they are fine. But what I suggest is a Hypergear ATR43SS2. It is a true bolt on turbo with hardly any modification required and will make the power no worries. No issues with the internal gate either.
What fuel will you be using?
thanks for you super fast reply :-D
i`ll use BP 98 octan / RON
Ou what i`ve forget to mention...i would like to have at least 550Nm at the wheels ^^"
Here`s my spec...
RB25det with aftermarket equal length low mount manifold (T3 flange)
- Head: channels smoothed but not really widened and standart valves and lifters, maybe tomei pon cams
- Block: Wiseco 87mm Pistons, RB26dett shot peened rods...with 1.1mm MLS HG (compression ratio was i think about 8.5:1)
- ARP bolts for Head and Rods
- N1 Waterpump and N1 oilpump maybe with Reimax internals...will see ^^"
- don`t know about the Bearings..if Nismo or ACL...
- Exhaust: 3 inch downpipe, 200cpsi Metall Cat, HKS Super Drager
WHATS EXACTLY THE ISSUE WITH THE KINUGAWA I-GATES? Are these too small?? Possible to widen them?
Edited by DK-Spec
Your clearance may or may not work depending on the manifold you have, as it isn't a stock one..
But with a standard manifold you can fit a 3582 down there. My car has a GTX3076R but doesn't actually need a spacer at all to get it to fit.
Going to depend entirely on your non-stock manifold though, would have to test fit or take measurements as that kind of changes everything..
XD engine isn`t build...most parts are still in boxes so...it`s not possible to show you the engine with the manifold fitted.
heres a ebay link that shows the manifold... http://www.ebay.com.au/itm/NISSAN-Skyline-R33-RB25DET-Turbo-Exhaust-Manifold-T3-MF6205-/190481976244?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c599c4bb4
i`ve bought mine second hand and i`m not sure if it`s exactly the same but as far as i know it should be the it..
Still have a stock manifold but when i can push few horses more with a better flow manifold i will do that ^^" If it`s not possible to fit with China manifold i`ll take the Nissan one :-)
Important for me is that it looks stealthy! the Turbo should be as small as possible and big as needed to reach over 300rwkw/550Nm at maximum 20psi. i`ve heard and read that the stock valvetrain is suffering when boosting over 20psi...is that so?
yes i know about the cheap china stuff but...it was used about 10000km so i hope the critical time which was prone to crack is over and the material is now ready for a real manifold life. btw. i will weld some reinforcement struts from flange to flange...to minimize the load on die piping...
more interessting is...how good these manifolds are in case of flow? O.o
So long as you like it.
I wouldn't touch it.
Is that your stock manifold? What's going on with cylinders 4,5 and 6? Did the engine die?
Edited by Ben C34
no no it`s not died :-D
I hope I will never have to experience how my motor dies..
In my R33 still lives the first Engine and it runs pretty well but i`m sure it will not live forever and because it`s old and i don`t know about his life before ME i`ve decided to buy a second RB25det to built it and make it as proof as possible for my budget and the power. The first engine which is still running i will overhaul then...will be as new from factory :-)
So i have now a completet engine in boxes thats why i was able to make a Pic of both manifolds.
Is the oem manifold not restrictive compared to china?
Oh and.. i bought 2 years ago a RB25det with a strage damage...the owner had no idea what was wrong...
Car was STOCK only a catback and HKS mushrom. At Autobahn 120km/h 5. Gear the engine made BANG and run like a sack of nuts... I`ve bought it unopend for 280,-
As i opend it and pulled out the Crank 1 piston was still in a Cylinder ^^"
Don`t know how or why but the 1. zylinder Rod has given up his Job...the Piston was cracked and Rod was a 2 piece thing...well..piston was not in 2 as well...relly bad stuff in the Sump.
Zylinder not repairable i guess...for sure it must be rebored over 87mm...i doubt 88mm would be enough :-( Crank also destroyed...must be grinded a lot and i`m sure that makes it not better for more torque..
Edited by DK-Spec
There is an extend for either of the manifolds listed above, its obvious the aftermarket manifold managed to make more power on less boost.
Pink is using factory exhaust manifold,
Thick red is the Made in China manifold that cracked after this dyno day and binned.
Thin red is an properly made Brae side mount manifold, that is still going strong over 100+ dyno days.
Turbocharger used is an Older version of ATR43-SS2 turbo that is internally gated and direct bolton to factory manifold, dump pipe, water lines and oil drain. From memory E85 was used for this particular experiment.
And of course either of the manifolds are comparable to an proper high mount running 50mm external gate.
Exact same turbocharger, no other changes apart from an proper high mount and 50mm gate.
Latest result from current ATR43SS-2 internally gated bolt-on to stock exhaust manifold and factory dump pattern running p98 fuel can be found here.
In terms of the largest bolton or low mount turbocharger, we can build them way over 700HP. Except this type of log manifold and internal gated system can not discharge that much air that satisfy full compressor efficiency. So 300rwkws or around 500HP would be the largest recommendation if you are looking for a direct bolt on turbo.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
