Still have yet to have a serious convo on here lol I know some are better than others (turbos) but surely someone must of had a good run with the china gear?! A 9sec blue vlt in soom some time ago used a ebay manifold and that was still running fine after 40+ hard passes and 1000s of ks. My old gas turbine project was fine at 25psi and 630deg c. Let the haters hate and the metal fragments fly!
At least you are approaching it with a good attitude!
A guy in adelaide turbo'd and El falcon with an eBay spec turbo. Worked for him. Does that help?
Unfortunately I don't think that you will find much info on them.
Yeah it does thanks ben. Ive got a hell of a lot of mags (friends own a newsagency) seems about mid 2000s everyone from the nissans to ford 250s were into the china gear, some still are given 300+ people have bought the gt35 copy from ebay. Yolo I say so at least I can try 2nd time round and when it blows just get a garrett. I dont mind the extra work
I don't know the dude, just chatted at the track.
He mentioned that they are ok when you find the good ones. Which I imagine us hard to do.
I remember his turbo on the comp cover said "turbocharger" which I thought was funny. Maybe that's a clue to the good ones?
I watch a video the other day, a drift teams was using an cheap turbo so yeah occasionally there maybe a good one amongst the crap ones. The hunt is on, let the haters hate! Also going ebay wg shock horror! Im running a ebay boost controller, intercooler, pipe work, plenum and exhaust. Hell I should just put a massive sticker on "sponsored by ebay" haha
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
