I will be emailing kelford later today, thanks for the info.
And sorry I pissed off lithium that much... Lots of info, thanks guys! Bottom line is we can't really compare any camshaft from different brand because they are all measured differently.
Well no, they are all measured the same, you just have to know how to read the cam card
Cams aren't really that hard and people way over think them, IMO you choose a cam to suit the application/intended use of the engine
You also can not choose a cam for turbo because it worked in a NA, they are two different animals and need to be designed and built that way, simple explanation is NA needs air velocity turbos need air volume, that is the simplest explanation and as much as I can go a lot deeper in to this this thread is about cams, not head design intake designs exhaust design etc etc
  • Like 1
They quote 50 thou and 1mm. They are different values. They know what they are doing ;)
Yes you are right. I was looking at the valve lift curve which has them marked as the same thing. But the tables to the left show them separately. For these cams there are 4 degrees difference between the durations at 1mm and at 50 thou.
26_a_in_260_915_ex_252_915_32_33_e.pdf
26_b_260_915_32_33_e.pdf
RB26DETT_256-925_3233_e.pdf
If you have a 1:1 ratio of exhaust manifold back pressure to boost pressure (or better) choosing an NA cam is a good place to start!
True.....but when you say NA cam what you really mean is standard, OEM spec NA cam. Not a hot NA cam.
I mean a hot NA cam... big duration and lift.
I'm not sure I follow you. In order to minimise reversion of hot exhaust gas into the cylinder you want to keep total duration under control and you certainly want to minimise overlap - compared to what you would do for an NA engine. Are you sure you don't mean the exact opposite of what you said?
Cam talk rules. Can go on forever and get nowhere fast.
The one difference with double overhead cams is that overlap can be adjusted. So perhaps an aggressive na cam can be dialled back in to something more sensible with the turbo.
Cams are, more than most things, an exercise in matching lift/duration to all the other stuff you have going on (rev range, turbo, CR, etc etc etc). A 272 may be an absolute weapon on an RB30/26 but hopeless on a 26. I don't know I haven't tried one. My limited experience was to go from Poncam B's to a 256/252 combination on a 26. Car made less power on an extra pound boost but was quicker. The biggest difference was in the low to mid range. So based on that extrapolating to 272 I cant reconcile it with what I had.
Longer duration move your torque up the rpm range, which is more power. Careful cam selection can get you a wider torque curve which is what everyone is chasing.
The caveat was just to remind people that duration is measured at a small amount of lift. How much lift affects how much duration. Something to be mind full of so everything is apples and apples.
Ultimately if shorter duration made more horsepower you would keep stock cams.
What was the lift and love centres on the 256/252 cams, also did you check cam/bucket clearnces
on mine both sets of cams where setup on the dyno to give best response and most linear power graph as possible, not just dropped in and that'll do
If the stock cams had more lift I would have found a set to replace the Poncams, I may have found a lobe which [email protected], if this can be scaled down to a 32mm base and fitted to an RB stick it will be :thumbsup:
I am very sure, PM me if you like.
When boost pressure is higher than exhaust manifold back pressure (very few other than flat out race engines get this right) then you want overlap.
Ahhh, but now I see what you mean by "or better". You mean less ex manifold pressure than boost pressure. You see, seeing as that is relevant to approximately zero percent of us, I assumed you mean the other way around.
Continue on as you were!
So you have a result of a race engine which has less exhaust manifold pressure the boost pressure cause that is something I would like to see proof of, ie a data log
Higher duration cams on any turbo application is not the best way of building them unless you want it to rev it to the moon which defeats the purpose of turbo charging
Duration is the working range of your engine, different turbos can blur this and unfortunately good is the enemy of better
this is a theory I have had since I first started building turbos engines back in the 90s and was proven to me when we turbo charged a mates 20v R1 and I have the reason why but I'm gonna let you try and figure it out for your selves
When I get to it I will measure it not to prove it to anyone but having higher boost than manifold pressure is what I want to achieve and I won't know without measuring.
overlap will depend on your static comp ratio.
no point in having huge overlap unless you have 11:1 comp or something crazy.
its all about matching everything to where you want the power to be made.
either way
lots of lift is good on these motors
btw lots is a relative term.
unless someone with more money than I can develop an aftermarket head for rbs with raised ports larger cam journals that are raised and bigger diameter lifters.
so we can see what .600+ thou lift does
I've pesonnaly never seen it happen and can't imagine it's possible and I have been involved in a few turbo charged race car builds, the only way to lower manifold pressure is bigger exhaust housing and bigger turbine wheel, both of which induce lag, the turbine would need to be bigger then the comp wheel for starters
Then add to that you want to use high duration cams, I hope your happy to rev this thing past 10k chase my guess is your going to have to
The only reaso you use high duration cams is if you want to increase your high range
What can be considered as high duration ? Is it dependant on the engine make or theres some sort of concensus ?
You went with TYPE-R, if you could, wouldn't you have prefered if it came with a higher lift ? like 10.25 ?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
