Venting the can to atmosphere is illegal and unnecessarily dumps really nasty crap into the air. You should plumb the vent into the factory breather fitting, that is, insert the catch can in the factory system, in the line that runs from the cam covers to the connection in the inlet.
If you do that, you'll totally get more hot babes because you will be far more awesome.
https://www.sau.com.au/forums/topic/449559-catch-can-smoke/#findComment-7406054
Thankyou for your comment. Driving it like a granny as I want to preserve its life for as long as possible. And my question makes reference to, what could be the possible cause of the lowish compression, rings or valves?
Pull the plugs. Squirt a little oil into each cylinder. Retest. If the compression comes up it its more likely to be rings. If not then valves. But having said that with the uniformity that you have its more likely rings.
https://www.sau.com.au/forums/topic/449559-catch-can-smoke/#findComment-7406114
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
