Sadly the car has been written off by insurance. Below are the items which arent standard from a factory R33 GTR. Everything was bought brand new other than the ECU
1) Nismo Fuel Pump and full major service done with N1 water pump at 90,000km+, Currently 125,000km+
2) TE3718x9.5 +12 265/35/18 Michelin PS2 Porsche (tyres bought less than 10,000km ago and rims 2 yrs ago)
3) N1 Engine and N1 turbos
4) N1 19 rows oil cooler
5) N1 oil pump
6) Tein Super Street Coilover at 80,000km+
7) Project MU SCR Rotors front and rear at 90,000km+
8) Stock Brembo with Nismo R Tune pads at 90,000km+
9) Clear front and side indicators
10) ERD rebuilt gearbox with Nismo Coppermix Twinplate at 100,000km+
11) Apexi PFC and boost controller kit
12) Factory carbon wing
13) Trust Ti-R catback titanium exhaust (slightly blunted as per photo but can be cut)
14) HEL braided brake and clutch lines at 80,000km+
15) Engine seal at and engine mounts 100,000km+
16) Iridium spark plugs at 110,000km+
The parts of the whole car would be worth way more or you could just buy the car and repair it yourself. The attached zip folder contains all the photos. This is a genuine N1 with Nissan FAST verification. $9k for the whole wreck pick up in Brisbane. This will need to go ASAP.
fwdphotos.zip
https://www.sau.com.au/forums/topic/449972-r33-gtr-v-spec-n1-wreck/
Congratulations to the buyer :)
If he'd like to PM me about insurance, I'm happy to offer info within the scope of what I know.
And...
All the best to you Brandon...
Sorry to see her go I bet?
I'll update you when its all finalised. Its either going to a close mate that helped me do a lot of the work on the car or I'll use this as an opportunity to fix all the problem which you were going to if you got it if its financial within my limit.
I hate to let it go after this mate of mine reminded me how much effort and time I've spent on her. And my wife telling me its our wedding car. Lol.
Still waiting for quote from the panel beater and some parts from supplier. If the cost is within limits maybe its a good opportunity to restore the entire car. I'll create another thread detailing all the work if it goes that way.
If not, it'll end up with my mate and he will restore it himself since he's a mechanic by trade.
Biltz: You can close/lock this thread if you wish.
Edited by Brandon
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
