Sadly the car has been written off by insurance. Below are the items which arent standard from a factory R33 GTR. Everything was bought brand new other than the ECU
1) Nismo Fuel Pump and full major service done with N1 water pump at 90,000km+, Currently 125,000km+
2) TE3718x9.5 +12 265/35/18 Michelin PS2 Porsche (tyres bought less than 10,000km ago and rims 2 yrs ago)
3) N1 Engine and N1 turbos
4) N1 19 rows oil cooler
5) N1 oil pump
6) Tein Super Street Coilover at 80,000km+
7) Project MU SCR Rotors front and rear at 90,000km+
8) Stock Brembo with Nismo R Tune pads at 90,000km+
9) Clear front and side indicators
10) ERD rebuilt gearbox with Nismo Coppermix Twinplate at 100,000km+
11) Apexi PFC and boost controller kit
12) Factory carbon wing
13) Trust Ti-R catback titanium exhaust (slightly blunted as per photo but can be cut)
14) HEL braided brake and clutch lines at 80,000km+
15) Engine seal at and engine mounts 100,000km+
16) Iridium spark plugs at 110,000km+
The parts of the whole car would be worth way more or you could just buy the car and repair it yourself. The attached zip folder contains all the photos. This is a genuine N1 with Nissan FAST verification. $9k for the whole wreck pick up in Brisbane. This will need to go ASAP.
fwdphotos.zip
https://www.sau.com.au/forums/topic/449972-r33-gtr-v-spec-n1-wreck/
Congratulations to the buyer :)
If he'd like to PM me about insurance, I'm happy to offer info within the scope of what I know.
And...
All the best to you Brandon...
Sorry to see her go I bet?
I'll update you when its all finalised. Its either going to a close mate that helped me do a lot of the work on the car or I'll use this as an opportunity to fix all the problem which you were going to if you got it if its financial within my limit.
I hate to let it go after this mate of mine reminded me how much effort and time I've spent on her. And my wife telling me its our wedding car. Lol.
Still waiting for quote from the panel beater and some parts from supplier. If the cost is within limits maybe its a good opportunity to restore the entire car. I'll create another thread detailing all the work if it goes that way.
If not, it'll end up with my mate and he will restore it himself since he's a mechanic by trade.
Biltz: You can close/lock this thread if you wish.
Edited by Brandon
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
