Rb26 Powered E30 M3
SSM
Awesome thread, will be awesome to see a finished product. Will you continue to track it when you finish the RB build?
That is the plan. But for 2015 me and my friend have a 7000km trip to the Alps planned. So that is the main goal for next year. Italy, Monaco, Switzerland and so on.
  • Like 1
THIS IS M.I.N.T!!!!
May seem like a silly question. Why not the S54 3.2L and 6psd vs RB26 and 5spd?
Main reason is that I want my car to stand out. There is a LOT of S54 E30's being buildt in Norway at this time. And I have always loved the RB26 sound, and I have dreamt about swaping an RB into something. So it was time to make a boy dream come true. Just hope I can get this to be as reliable as the BMW engine was/is.
Fair enough. I get building a "different" car to the masses. I was looking for an E30 M3 for a while and ended up getting my 80s on with my Sierra Cosworth. Will end up with an E30 M3 one day, though sadly will never realise my dream of one running a Judd V8
My friend have a 86 Cosworth. It will be that car and mine that is going to cruise the alpine roads august next year. He is doing a complete rebuild of the YB engine and some DTM parts.
  • 1 month later...
Got some more photos of it on email. I can see some rust on the flange, but I also noticed that there is these small braces from the flange and onto the turbes. I remember seeing that on the CX racing ones if I remember correct. Another thing is that the 6Boost manifolds are coated anyway, am I right?
Update time!
I have not done much with the car itself. There is winter here in Norway, and I f**king hate to work in a cold ass garage when I actually don't have to. So I have just been collecting more knowledge about the RB26, as well as collecting parts and working out solutions in my head.
I was surfing Ebay and stumbled over a swap kit for RB26 in 200sx. It was fair price so I just bought is. Figured that it is more easy for me to modify them mounts, rather than te stock aluminium mounts. To be honest, I don't think it is that much off. Have not had the time to test it on the engine yet.
From USA company Wiring Specialties. They are making custum wiring harnesses for different cars and applications. I found ound that they was actually making a RB26 harness for the E36. So I emailed them and told them what car and model I had, and they could make one custom for me.
So I sourced a C101 plug (BMW interface) on Ebay in USA and just got that shipped directly to Wiring Specialties. So now I have a plug and play harness for the RB26 in my E30M3, hopefully.
Another benefit is that the Japan wiring harness is not having a good rumor in beeing of high quality. This makes my build more reliable and safe from electrical problems caused by an old harness. Everything in this is new, all the plugs and connectors is new. I have read that people have had problems when mapping PNP stand alone engine management systems, that is caused by a bad stock harness.
Another thing that Wiring Specialties do with this harness is that they clean it out. They route it a bit different and some boxes, relays, ignition amp and injector resistance is moved to inside where the ECU will be fitted. So the engine itself will look more clean. The wires for the injectors for exaple is now routed under the intake.
This this costed me a lot of money, so I'm just hoping it will work as it should. Only thing I need is a BMW oiltemp and water temp to get correct reading in my cluster. Also need to solder 3 or 4 wires. For the reverse, speed signal and rev counter I think. Have not had a good enough look at it yet.
  • Like 1
  • 3 weeks later...
Bough myself a bottom mount manifold. Claimed to be out of a old HKS kit. This is just a test project to see if I can use a bottom mount single setup, but the main plan is to cut off the flange and turn it over to a top mount manifold. Would also need to angle the T4 flange as well.
  • 2 months later...
Okay, so, I have got some work done. The engine is now fully stripped down and I have made a deal with a engine shop to take care of the internals for me. And since he has a lot of work to do now, everything is on hold.
There is no rush when building something like this anyway. I have made a list for a shop in USA that sells almost every part that I need, so I'm waiting for a final quote on the price there.
The cylinders looks good, so there was no unpleasant suprises when I opened the engine.
Here is how each main bearing looked. I'm no engine expert, but there was only significant ware on the number 1 bearing.
Since it is late model R32 GTR engine, the crank has the long nose. Saved some bucks there!
One random shot of the crank
Started to take apart the head and placed the parts in order on the bench. Rest is up to the engine builder to take apart.
And a complete stripped block. Ready for wash, hone, deck and some drilling.
Till next time
What will be done to the bottom end is:
-Fully balanced crank together with flywhee, clutch and harmonic balancer.
-Balanced stock rods and pistons
-Hone and deck the block
-Drill the return galleried to match the head gasked (10mm)
-JUN high flow oil pump
-1.2mm gallery restrictor
-New race rod and crak bearings after the machine shop have taken correct masures of the clearances
The head will get a full check with pressure testing and flow testing. Drill the return galleries and make the oil entry better.
New decking for the head as well as a good cleaning job.
The total long block will be packed with stock main bolts, because ARP is not needed for the power I'm aiming for.
There will probably be ARP bolts in the rods, ARP in the flywheel and ARP head studs. Cometic complete gasket kit for the top end and bottom end.
The long block will be put together by the machine shop, so I'm picking up a new buildt long block.
I would love to get some inputs from you guys if you think I'm doing this the correct way.
Should I maybe cost a new set of rods and pistons now when I'm first at it?
Aim is not more than 500hp anyway. I'm probably going top mounted upgraded stock twin turbos on custom manifolds.
    • The housing it self made minimum differences, while the exhaust manifold made a difference. 6 Boost T3 divided will do fine. ATR43SS3ProR model in T3 .82 rear (TS optional) from March 25th will be more then capable of 450whp with excellent response.
    • The boy crashed his Patrol a while ago, so he is now driving his mum's ASX and she is driving my Honda I initially said he could have the Honda to drive around (he's a good kid currently training at the police academy), but, his mum was quick in saying that he "will" take the ASX and she will take the Honda, he was a bit upset with that, he rates the manual Honda more than the automatic ASX (mums taxi), and I'm getting the feeling she enjoys thrashing the manual Honda around In other news, I'm looking at a MX5 NB series 2 on Saturday  I always loved my NB series 1, but after stripping it down because I'm a idiot it wasn't fun cruising or driving around daily, and Jackie refused to drive it, which was an issue if we went out, because her refusing to drive it meant I lost my designated driver if we went to a party, or dinner, or...... basically anywhere where I could get a glow on Yes yes, I may need a new job if I decide to buy https://www.seek.com.au/apprentice-hairdresser-jobs/in-All-Sydney-NSW Plus giving the Honda to the boy, which is my cunning plan, will give me enough wifey type credits to turn up in another car Meh
    • Yeah I've just been checking it out on GTR registry and its the emerald green pearl (DS0) and only 610 made for S1 RS-Four V (if i'm understanding correctly) so I feel obliged to restore the paint to as close to original as possible!
    • Thankyou, sir! Yeah I'm having a lot of fun rewiring bits of the car. I used to dislike wiring a lot before, I dont like it any more but it is getting easier
