Awesome thread, will be awesome to see a finished product. Will you continue to track it when you finish the RB build?
That is the plan. But for 2015 me and my friend have a 7000km trip to the Alps planned. So that is the main goal for next year. Italy, Monaco, Switzerland and so on.
  • Like 1
THIS IS M.I.N.T!!!!
May seem like a silly question. Why not the S54 3.2L and 6psd vs RB26 and 5spd?
Main reason is that I want my car to stand out. There is a LOT of S54 E30's being buildt in Norway at this time. And I have always loved the RB26 sound, and I have dreamt about swaping an RB into something. So it was time to make a boy dream come true. Just hope I can get this to be as reliable as the BMW engine was/is.
Fair enough. I get building a "different" car to the masses. I was looking for an E30 M3 for a while and ended up getting my 80s on with my Sierra Cosworth. Will end up with an E30 M3 one day, though sadly will never realise my dream of one running a Judd V8
My friend have a 86 Cosworth. It will be that car and mine that is going to cruise the alpine roads august next year. He is doing a complete rebuild of the YB engine and some DTM parts.
  • 1 month later...
Got some more photos of it on email. I can see some rust on the flange, but I also noticed that there is these small braces from the flange and onto the turbes. I remember seeing that on the CX racing ones if I remember correct. Another thing is that the 6Boost manifolds are coated anyway, am I right?
Update time!
I have not done much with the car itself. There is winter here in Norway, and I f**king hate to work in a cold ass garage when I actually don't have to. So I have just been collecting more knowledge about the RB26, as well as collecting parts and working out solutions in my head.
I was surfing Ebay and stumbled over a swap kit for RB26 in 200sx. It was fair price so I just bought is. Figured that it is more easy for me to modify them mounts, rather than te stock aluminium mounts. To be honest, I don't think it is that much off. Have not had the time to test it on the engine yet.
From USA company Wiring Specialties. They are making custum wiring harnesses for different cars and applications. I found ound that they was actually making a RB26 harness for the E36. So I emailed them and told them what car and model I had, and they could make one custom for me.
So I sourced a C101 plug (BMW interface) on Ebay in USA and just got that shipped directly to Wiring Specialties. So now I have a plug and play harness for the RB26 in my E30M3, hopefully.
Another benefit is that the Japan wiring harness is not having a good rumor in beeing of high quality. This makes my build more reliable and safe from electrical problems caused by an old harness. Everything in this is new, all the plugs and connectors is new. I have read that people have had problems when mapping PNP stand alone engine management systems, that is caused by a bad stock harness.
Another thing that Wiring Specialties do with this harness is that they clean it out. They route it a bit different and some boxes, relays, ignition amp and injector resistance is moved to inside where the ECU will be fitted. So the engine itself will look more clean. The wires for the injectors for exaple is now routed under the intake.
This this costed me a lot of money, so I'm just hoping it will work as it should. Only thing I need is a BMW oiltemp and water temp to get correct reading in my cluster. Also need to solder 3 or 4 wires. For the reverse, speed signal and rev counter I think. Have not had a good enough look at it yet.
  • Like 1
  • 3 weeks later...
Bough myself a bottom mount manifold. Claimed to be out of a old HKS kit. This is just a test project to see if I can use a bottom mount single setup, but the main plan is to cut off the flange and turn it over to a top mount manifold. Would also need to angle the T4 flange as well.
  • 2 months later...
Okay, so, I have got some work done. The engine is now fully stripped down and I have made a deal with a engine shop to take care of the internals for me. And since he has a lot of work to do now, everything is on hold.
There is no rush when building something like this anyway. I have made a list for a shop in USA that sells almost every part that I need, so I'm waiting for a final quote on the price there.
The cylinders looks good, so there was no unpleasant suprises when I opened the engine.
Here is how each main bearing looked. I'm no engine expert, but there was only significant ware on the number 1 bearing.
Since it is late model R32 GTR engine, the crank has the long nose. Saved some bucks there!
One random shot of the crank
Started to take apart the head and placed the parts in order on the bench. Rest is up to the engine builder to take apart.
And a complete stripped block. Ready for wash, hone, deck and some drilling.
Till next time
What will be done to the bottom end is:
-Fully balanced crank together with flywhee, clutch and harmonic balancer.
-Balanced stock rods and pistons
-Hone and deck the block
-Drill the return galleried to match the head gasked (10mm)
-JUN high flow oil pump
-1.2mm gallery restrictor
-New race rod and crak bearings after the machine shop have taken correct masures of the clearances
The head will get a full check with pressure testing and flow testing. Drill the return galleries and make the oil entry better.
New decking for the head as well as a good cleaning job.
The total long block will be packed with stock main bolts, because ARP is not needed for the power I'm aiming for.
There will probably be ARP bolts in the rods, ARP in the flywheel and ARP head studs. Cometic complete gasket kit for the top end and bottom end.
The long block will be put together by the machine shop, so I'm picking up a new buildt long block.
I would love to get some inputs from you guys if you think I'm doing this the correct way.
Should I maybe cost a new set of rods and pistons now when I'm first at it?
Aim is not more than 500hp anyway. I'm probably going top mounted upgraded stock twin turbos on custom manifolds.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
