Folks, what is the easiest way to get the bolts out of the top mounts of coilovers. The bolts on mine dont have a hex head or allen key, they are simply round. The thread on the bolts is stuffed so I need to remove them and replace with other bolts. Any ideas how I can do that?
Cheers
Amir
https://www.sau.com.au/forums/topic/450994-removing-bolts-from-top-mounts/
Generally if there is no hex key in the top of the shaft there is a small flat section below the top where you can hold a spanner. If not I guess you need to try a rattle gun, and if you don't intend to reuse the coilovers lock a set of vice grips onto the shaft nice and tight.
Don't forget spring compressors before you start.....
Photo please. Duncan is talking about taking the nut of the shock piston (which is how you get it apart) but you said you want to replace them with other bolts, which sounds like you want to replace the piston.... Not making sense to me
Apologies guys, I should have been more clear. Yes I am talking about the studs which stick out of the shock tower. I removed some from my old suspension but these had an alen key head and were easy to move. I found that there is a small thread in the camber plate which they screwed into. Im assuming the ones I'm trying to get off are similar and have a thread in the camber plate/top mount so I dont really want to hammer them through so as not to damage the thread. Will upload photos soon
Cheers
Amir
They are punched/pressed in, in exactly the same way as wheel studs are fitted to hubs.
Put a socket under the stud so the stud can fit through the hole in the socket, sit assembly with the socket on a sturdy bench, whack threaded end of stud with a hammer so its pushed out into the socket.
The whole idea of the socket is to support the camber plate while hitting the stud back out into it.
If you find new studs to knock in and they fit a little too easily, you can go around the camber plate, right next to the stud hole with a center punch, this will shrink the hole a little to make the new stud a tighter fit.
Cheers Peter. But what if the studs actually screw into the plate? As I mentioned before, another set I tried - the studs were screwed in rather than punched/pressed in. If this is the case with these ones then hammering them out will damage the thread in the camber plate. Any ideas?
They won't be screwed in if there's no flats on the head to use to torque them up.
Exactly what he said. If they were screwed in then no need for the mushroom head underneath and there would have been a method to drive them in by a tool.
I highly doublt that they are threaded into a aluminium hat and just hold via some threads in alloy, notice the large flat mushroom head from underneath?
Its so they dont pull through the alloy when tightening the nut.
They are studs just like on wheel hubs.
I have seen a few manufacturers use this method on coilovers and normal struts on OEM assembies, we had one broken on the rear on our GTR, it was snapped off by the previous owner, when looking at it it was a punched in stud, next time i have the rear coilovers out i will be punching it out to replace it.
Support the yellow alloy top from under where the mushroom head of the stud is with a socket that is large enough for the musroom head to fit through as you hammer it down.
You need something tubular like a socket to fit around the stud but not touch it, it must sit against the yellow alloy top to support it and provide room for the stud to pass through.
I managed to get 3 out of 4 studs out. I grinded some of the stud off, hammered it down and finished the rest of with a nail punch. One stud I cut to close to the camber top and I cant hammer it down and the nail punch is simply not doing anything. The stud is sitting flush with the camber top and seems to have welded itself to the camber top from all the hammering etc. Any ideas?
  • Like 1
Heavier hammer with the punch?
This.
Use a solid punch that covers the whole stud face that you cut and use a heavyier hammer so you have some force behind it.
I wouldnt have cut the studs.....
Edit, i just noticed your using a nail punch NOooooo......use a pin punch thats a similar or slightly smaller diameter than your stud.
http://en.wikipedia.org/wiki/Punch_%28tool%29
Edited by GTRPSI
Thanks for the help boys. Finally managed to get them all off by hammering them, punching them through and swearing at them. All that work and when I was looking at one coilover when it was lying on the ground noticed it was slightly bent. So I have to get it to the suspension place and see what they say. Good times
Amir
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
