...and if Renault do buy Lotus I hope they boot Paster and get Hulk in the seat. The team could do wnders wuth Bell and a bit more budget
They'd have more of a budget if they weren't rebuilding maldonado's car every time he crashes it (in other words, every round)
  • Like 1
Monza is by far and away the shittest track on the calendar, there is no joy watching a drag race surrounded by one eyed inbreeds
There is a great elegance in not coming here and shouting Forza Mercedes in other fans faces
How have we not progressed from places like this, its amazing
Bahrain second, Melbourne third
Well them and the rest.
Ferrari are the closest to challenging MB but they aren't close.
RB is stuffed and will have to run Ferrari engines next year as MB told them to sod off.
Williams don't have the money to improve their car quickly enough.
Lotus are going broke and are waiting on a Renault buy out which is their only chance.
The less said about McLaren the better.
Sauber have no money.
Force it India have a bit more than Sauber but not enough to be competitive.
Torro Rosso will never amount to anything.
Manor will be lucky to be around in two years time.
Oh and Britney cant get anywhere near Hamilton.
So its all going well then.
Best thing about the Monza telecast was the BRM from 1971.
Monza was an OK race. Although DRS still gifts a place, making overtakes a non-event in most cases.
The bullshit surrounding F1 continues. The FIA imposed 168 places worth of penalties, Ricciardo was demoted 50 places due to engine and turbo swap. Alonso got dropped 10 places, Button 5 places. Who f**king cares? All these top drivers starting out of place at the back of the grid. FIA have lost the plot.
Also, there was some drama about Merc's tyre pressures late in the race. They were within the rules when the tyres came out of the blankets, the FIA decided to "spot check" them on the grid after they had cooled down and then found Merc to be below the minimum required pressure. Of course they will be! Ferrari obviously knew this was going to happen and pumped their tyres up a bit. But Merc ended up not being penalised, which is fine. But Merc told Lewis to speed up in the last few laps, but not why. Why is now known - to cover off a potential FIA penalty for having cold tyres with less pressure in them. Who f**king cares???
Too many goddamn rules.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
