**** For Sale **** - Nissan Skyline 93 R33 Gts-T
For Sale
Nissan Skyline 1993 R33 RB25DET 5 MANUAL $7999 ono
Selling my R33
This Skyline was always serviced every 2000km with Genuine Oil filter.
There is no problem with the Skyline, no oil leaks "Guaranteed". It has had a fresh paint job 1.5 years ago. The skyline loves long long trips, even short around town trips.
The engine has been rebuilt when imported, couldn't get receipts off old owner. But I stripped down the engine to do a major service and could easy see new gaskets and no oil built up. (I have photos !! )
- RB25DET
- 450 HP Turbo (12psi)
- FMIC
- New Heavy Duty Clutch
- New Genuine Radiator
- New Genuine Coolant
- New Genuine Fuel Filter
- New Spark plugs (.7 gap)
- New Thermostat
- New Gates Water Pump
- New Gates Racing Timing Belt kit
- New Drive Belts
- New Radiator Hoses
- New Genuine Tapper Cover Gaskets
- New Genuine Inlet Gaskets
- New Pod Filter ( with custom inclosed box)
- Rocket and Timing case Painted ( Same colour as the car)
- GTR Fuel Pump, Plus a spare.
- Stainless Steel 3inch exhaust with High Flow cat, 3.5 inch stainless steel cat back. And Middle Stainless steel muffler.
- King Springs
- Zumbo Yako 18x8.5 Front needs replacing soon. 18x9.5 Rear New Tyres
- LHF Guard Sticker Bomb.
- Interior in good Condition with Boost Gauge
- Greddy Turbo Timer
- Resprayed 1 and half years ago.
$7999 Ono
10 months rego
Located - Wagga Wagga
PM or txt (0422866407)
Edited by Supple k
 Share
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
