were the pads you tried OEM or aftermarket?
sometimes aftermarket pads do not sit the exact way OEM pads would and leave a bit of a gap and may be sitting a bit loose in the caliper. Go supercheap and buy some brake squeal stop or whatever its called. Its a red paste you spread on the outside of the pads and once it drys, it becomes rubbery and helps bridge small gaps you may have between the pad and caliper.
Edited by Abdul11
na i dont iv'e been trying to buy some can't seem to find anyone who sell them iv'e always put FB status's on drift sales and other pages, i went to my local nissan dealer my they said you have to go to a bigger dealership like doncaster Nissan or some shit also i took my caliper off today and i saw my rubber on my brake piston is cracked and exposes the piston a little do you reckon that could be a reason, i might try a full caliper rebuild
haha ill do a full rebuild next week and ill see how it goes, does anyone know where do get some brake shims honestly iv'e been looking over two month's cant seem anyone who have any
A wrecker.
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
