I'm having a 30 bottom end built with the stock crank, forged Pistons and rods and the whole thing will come out to about half the cost of a stroker kit off the shelf
That's the upfront costs.. If you have a GTR the you need a 4wd adapter plate, the block sits higher so your pluming and exhaust needs to be modified, I'm sure there's plenty I've missed.. It's the small things that add up
Yup everyone thinks its easy to just slap a Rb30 together for a GTR. If its twin turbo its a mission since it lifts the head up 35mm. When I did my build it was a minimum of $4000 extra on top of my forged motor. So I set about keeping as god intended it. 2.6L TT. Sort of wish i went a nitto stroker haha.
  • Like 1
I was considering the 30 for a while, the. Decided it was just easier a d cheaper to build a 2.9 stroker..
Got to use a few old parts and I like the idea of keeping the standard sized block
With the 3.0 and the comp housing on your turbo, it would be hanging out of the bonnet!
Dollar for dollar the RB30 is cheaper, mine as example
RB30 complete motor $150 :yes:
Prep crank with collar $500
Adaptor plate, platinum race( the dear one ) $1250, can be done for $500
Machining for adaptor plate ( included close girdle and line bore ) $1700, not needed for other adaptor plates
Forged Pistons and rods delivered from states $1500
ACL race bearings ( mains and big end ) $250
That brings you to the start point of a stroker so the rest would be the same
$150
$500
$1250
$1700
$1500
$250
=$5350
And the extra drive you get from the 30 crank is soooo much better
I used R32 GTR twin turbo and plenum hoses which fit perfect and look stock as
I was getting a new exhaust anyway and it starts from the CES dump pipes
Intake was taking care of with the R32 hoses going from twin turbo pipe to chassis and plenum to chassis, though if you have a 32 that won't work :(
Oil returns was a -12 bung welded onto sump
I believe if the block is older than the car it has to meet the emission standards of the model of car its in.
ie it would have to be bone standard and im240 tested etc
doable on e85...but e85 needs an aftermarket ecu....so technically not legal.
If you're getting it engineered then a passed IM240 means you can bypass the block/car age issue, non-factory tune issue etc. Of course that only covers tailpipe emissions - you still need charcoal canister, plumbed in PCV etc. (Assuming i understood what the Engineer said at the SAU NSW tech evening).
Try fitting a Tomie pump on a RB30.
Wont go straight on, sits 2.7mm out from the block.....more mods with a die grinder.
So much more than meets the eyes......
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
