Hi guys,
After a little bit of help with my build, Car is currently undergoing a restoration and while it off to be painted i have stripped all ancillaries etc off the block ready to clean it up.
I have a Holset HX35 To go on when the cars back and will be buying a 6Boost Mani to suit and other supporting mods.
I am a little stumped on the inlet side, There is 2 options im thinking of.
  1. Buy a Freddy Greddy copy plenum with throttle body and fuel rail, If TPS Doesnt fit straight on modify it to fit, Remove all Idle valves, and other sensors etc that dont fit. I know i wont be able to fit the AAC Valve, but what else will i have to remove? Am i right in thinking my only idle setting then will be on the TB Screw? Will also have to make up new fuel lines etc, and im also unsure on what injectors i would go with? High impendance top feed i know that.
  2. Buy a plazmaman manifold and throttle body, at the price of £1200ish in the UK. This appeals to me due to quality etc, but once again what sensors etc do i need to remove? Does it keep the AAC Valve etc? Bit put off by the price to be honest...
  3. There is also the modded stock option and retaing all stock stuff, but not too keen on this idea
Car will also be running a Haltech Platinum pro plug in, Will be retaining A/C.
If i can fit a Greddy and remove all the OEM Idle and AAC Valve etc and get away with setting a base idle of say 1000rpm i will, Will the Haltech be able to adjust idle using the TPS and setting it up well?
Thanks
Chris
The Greddy plenum gives you flanges to bolt your iacv and cold start valve to on the underside of the plenum so you can retain both neatly. As for the plazmaman plenum, it's only the top half and you retain the stock runners so you can basically keep everything on the intake side as per usual
Why do you want to remove your idle / aac valve?
Is that applicable to the GTT Though Jord? And i dont want to remove anything, i was just under the impression i would have to with the greddy setups.
Hmm, good point actually.
Here is a photo of the underside of my Greddy plenum, while it is for an R33 RB25DET I'm sure it would be quite similar underneath? sorry for any confusion :)
EDIT: sorry that photo is average, it's the only one i have on my phone at the moment! :P
Edited by Jordy32
Thanks for that guys, Made my mind up today and purchased a greddy copy with TB And injector rail, Will be buying an adapter from Ben C34.
Stock inlet I really dislike, looks,heats oak, just not for me.
only problem I may have now is the TPS. How do people usually do this? Is the stock TPS the same drive?
I'm not retaining the TCS,And stock manifold again I'm not retaining for the reasons above. May still swap to an R33 TB & adapter for ease if I need to.
And has anybody any proof of all this mid range torque loss? The power graphs I have seen on decent setups don't loose torque by much.
And Rb20 torque wise I'm sure is a joke.
I'm also aware that a stock size throttle body will flow massive power, So it's not because it's not big enough.
I can help out.....
This ^ guy made me some adapter plates. PM me if you want me to send you one, as I still have a few left over. It is just a plate that allows you to bolt your r34 aacv to the 33 mounts.
Thanks for your help guys.
Plenum is here now and I'm impressed by the quality of it all. Will be fitting it with an adapter from Ben.
One final question regarding injectors, I know I need top feed high impendance to go with the NEO motor/HKS Rail and found these ebay item number: 201145001596
Are they any good? And genuine for that price? Aiming for around 450-500whp
Thanks!
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
