Cheers mate yeah were now pushing the 1900 mark for track width. Will hopefully get some time this week to play around with the rear diffuser abit more and will try add photos abit more regularly, i think i say that every time tho..
Yeah i love the look of it, yeah going to be going to about -3 and see how we go but i have a feeling were going to see -3 rear and -4 front in the end but at the moment i have absoloutley no data on them but do have abit of a plan of attack from a guy at racing ready in canberra he has been awesome giving advice and just chatting on FB etc..
Well i have been trying to pin down a couple of the little odds n sods jobs on the car that have been bugging me for a while, one being we have had no wipers for ages as when i was splicing the loom somewhere along the line they stopped working.. so traced back through and have rewired them so now we have fully functioning wipers.. yay haha will be good as were coming into crappy weather.
Also when we went to the dyno the E-Boost wasnt working and couldnt for the life of me workout why so just ended up running a boost tee until we could fix the problem and as it turns out with the E-Boost there are several boost maps and i was on a different boost map that i never even knew about so thats now fixed
Also wired up the E-Boost to display tach and have been wiring up some LED shift lights to the Haltech and that has been a drama in itself lol.
Weather is pretty crappy this weekend so will maybe try get brake ducts modified on the LHS of the car now and tidy up a couple of other loose ends.
Will post some pics tonight for everyone reading :)
Cheers
Didnt get quite as much done this weekend as i would have liked but new shift lights are fitted after abit of a headache. So a 5000, 6000 and 7000 rpm light so will now have abit more of an idea of where were at
Also tidied up the brake ducts that were once under the front bar i have now fitted them to the original indicator position and have moved the indicator to the original parker lense.
Well my new wing has arrived... to say im excited is a major understatement.
Cant use all 3 elements in Sports Sedan can only run a single element at 1830 wide or dual element at 1600 wide. The dual element will provide slightly more downforce but i think im going to just run the single for a while and try get the balance right. I dont think the wing will see the car for a while tho lots to do before hand.
With the long weekend approaching i am moving the car to a mates place to look into abit more aero design, so going to try make an undertray, front splitter and possibly look at starting a rear diffuser.
After abit of a curveball with work next week i didnt get to my mates place to throw the car over the pit to have a look. But i did manage to have a look at the front splitter and start designing it up.
So shot over to bunnings and got a 12mm MDF sheet and started cutting. Have mounted it to the front X member just infront of the steering rack, then also have 2 more bolts off the front caster arm mount and another 2 off the rad support. I have run 8mm threads down so that i was able to wind a nut ontop of the MDF so that i can lift or lower the splitter. So currently i have it level with the chassi rails so i think that will be a good starting point. Under acceleration it will lift up and chanel extra air into the rear diffuser and hopefully increase rear DF then under brakes it will dip and hopefully increase front DF. But i figure that there wasnt much point fitting the wing as ots just going to unbalance the whole car so see how it feels with the splitter.
Next will try filling out the floor pan and flatten that out then look at the rear diffuser and mounting the wing.
Cutout the undertray for wheel clearance but hopefully keeping air off the arms
Splitter mounts just need to cut through the front bar for the supports
Will be cutting out the bumper profile soon just want to get it all mounted 100% so then can do my 100mm for the maximum splitter length.
Haha cheers dude its possibly the single most expensive part that i have bought for the car to date...
Managed to pretty much finish the splitter there is still abit i want to do to it to get it 100% but for now its good. Just gotta build an airdam off it to get the most potential.
So with the splitter almost completed i have started looking at the undertray so now im going to have to redo the whole exhaust system to sit between the rail and floor. But unfortunatley the side skirts i hated have made a reappearance.. they sit perfectly inline with the rails so coming off the rails to the skirt would make a decent support.
Have been chatting to Josh from MCA and its looking like im possibly going to be saving my pennies and getting some red's as the next major purchase i think.
  • Like 1
How have I not seen this.
I LOVE sports sedans. Car looks great.
The only thing I can contribute is to consider running "used" careers cup slicks, most tyres barely see a race and can sell for $100-150 a tyre.
  • 3 months later...
Well i ended up having a customers car come into the shed for a whole heap of work... but i cant seem to add in pictures at the moment..
Well his cars out and the R34 is back in so i have been through the wiring loom again and removed the last of the original loom and wired up the wipers and brake night to my custom loom. So were slowly getting there but i have also focussed on the front splitter/bumper so have started shaping that in fiberglass and will try pulling a mould in a couple of weeks once happy with the shape.
Sorry i cant seem to upload pics this app isnt letting me for some reason :(
Just found this thread now, awesome build mate!! Couple of questions out of curiosity:
Have you driven the car in anger yet with the MDF splitter, does it take bumps/kerb/abuse ok?
Are you using the same material for the undertray? I wonder how it would go with the heat from the engine bay?
What did you use for brake ducting? Looks like a pretty large diameter duct in the photos. Also did you find/fab a flange to connect it up to? I've been chasing some that would direct the airflow to the centre of the disc but they're pretty tough to find...
Nah once i got the splitter on and even with the supports i didnt like it so thats why we are doing the fiberglass bar abit earlier than planned as the new bar design incorporates the splitter so i will be able to give it sufficent strength and support. I think if you used maybe 19mm mdf it would be fine but the 12mm i dont think has enough strength and for what the 19mm would weight i think it would out weigh any benefits.
The undertray is going to be from ACP (aluminium composite panel) like diabond as you can get it in 6x2m sheets so i can have the floor as a single piece. I have seen people use the diabond in wheel tubs so i would expect it to be strong enough and withstand heat.
The brake ducts at the moment are actually 4" aluminium range hood ducting from bunning so it was like $10 for 2.5m instead of the racing stuff at like $30 per foot. In my opinion it is too big.. i was struggling to actually get the brakes warmed up around mallala atleast. There currently just attached to the lower arms. Once i get abit more confident with the fiberglass i plan to make a hat that blows into the center of the disk and out the vents in the disk. And only have 2" feeding it.
Good call on the splitter material.
This splitter install on an 86 is pretty cool with the turnbuckles, I'm keen to try something similar at some point: https://youtu.be/LvEbqTv-my4?t=2m25s
Also the one on this RX7 build looks pretty trick, made out of alupanel: http://www.sau.com.au/forums/topic/447297-my-rx7-s8-track-car-build/?do=findComment&comment=7772399
Yeah the high temp brake ducting is very pricey... Also you're right the 4" seems huge, I had a good look around last weekend with the front bar off and I would probably struggle even with 2" duct on the driver's side as I have the PS cooler core taking up a lot of space there.
I cant see the picture maybe its an issue with my internet. Yeah i thought about turn buckles but unfortunatley this whole car has a pretty strict budget and i know the turn buckles and stainless were only gonna be probs $100 but i had the ally sitting in the scrap bin and figured what the heck.
That RX7 is cool i do like that! Might endup incorporating something like that into my splitter design.
Yeah i couldnt justify it to be honoust that was why i went the 4 and originally it was only sitting under the bar so how much air it was getting was actually questionable but once i fitted them to the indicator holes it was getting too much cooling.
So thats the new front bar design. So the small opening in the center will be the new inlet for the new radiator/IC design so that should be some fun in the future. Were going to be going to a jeep radiator and cutting up the tanks abit and laying it flat near the cam sensor and making a vent out the bonnet so see what happens but it should be fun. The cars now getting abit out of hand and i really just want to drive it but im currently really enjoying making the custom bits
  • Like 1
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
