The top tank on my 01 M35 2.5T went today so I will start the hunt for a new rad here in Perth today (yeah, wish me luck!).
I know that the Koyo v35 skyline ones fit but apparently they come in two versions- pin mount for the fan shroud or rectangular hole mount. Any idea which one we have?
Ta
https://www.sau.com.au/forums/topic/452196-which-radiator-m35/
Thanks Josh- that's what I did last night. The first one that comes up says :
"PIN BOTTOM FAN MOUNTS PLEASE CHECK FOR RECTANGLE MOUNTS PLEASE CHECK ITEM NUMBER:191157820160"
which is why I thought I'd ask... :)
Well fancy that. Local Natrad had one- $285 and it's mine. Looks like I'll be having a fun start to 2015 tomorrow!
just ordered PIN one from ebay for my 2003 M35 auto. i am not aware there are 2 types of rad. what's your model?
I just bought this golpher 686mm wide radiator from e-bay.
http://www.ebay.com.au/itm/NISSAN-SKYLINE-V35-AT-MT-POLISHED-ALLOY-RADIATOR-CORE-400x686mm-/271079858068?pt=AU_Car_Parts_Accessories&hash=item3f1d9e5f94
it fit perfectly, thicker core than standard.
all good!
Hi there,
I have held on eBay with KOYO this morning and went to the seller's store of Golpher. Unfortunately it is close today. Will try to get Golpher one next Monday.
  • 3 months later...
Hey guys, Iv just purchased low temp thermo and new hoses for my nm35.. Alloy radiator is next on the list but there seems to be a few out there, Iv done a bit of digging but can't pin point what exactly is the best option, some require trimming the shroud etc, eBay has a couple of cheaper ones, a Sydney based one and one seems to be a Chinese one called winner racing ( doesn't sound like a winner to me)
Just want to hear best options/best price and feedback before I go and throw a few bucks at one.
Zach
Mishimoto is the pick tbh; koyo do an aluminium high performance version; but at $550 its significantly more expensive.
The Mishimoto will have to come the US, but is excellent quality.
  • Like 1
Which thermostat? I have tried a few and only the Nismo is any good. Mishimoto thermostat had the car in it's cold start map constantly and failed quickly not long after.
I have been buying the Fenix rads, the alloy and the plastic tank version. Other than lacking stock they are good quality and local in Sydney.
Try Alex at Moonlight Racing, www.mlracing.co.nz, he lists some Mishimoto radiators on his site already but I didn't spot a Stagea one, which isn't really surprising since no one seems to care about them. He's in Japan at the moment, I think he has a container coming back soon but I haven't heard a peep from him for a couple of weeks, probably because he found a pantie-dispensing vending machine or something.
Tell him Matty from CJC sent you.
  • Like 1
The moshimoto is not a stagea dedicated model. It is actually g35 model, hence it needing some trimming to the shroud etc.
Cheers mate, I have come across the website before I'll send an e mail. Thanks
  • 6 months later...
My top tank split this week. Lots of coolant everywhere!!!! Filled 3 times and local mechanic advised not to drive it. Given the hot weather it's probably worth while. So Mishi is the pick given the comments in this thread? Looked at the e-bay option but feel it's too cheap and nasty :-(
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
