Hello so I've brought a R33 Gtst. My first ever turbo car. Im looking to get it around 350 HP at the wheels. Now I've been doing a bit of research and I think I've found a good list of parts I need to make this possible. Just want to see what you guys think before I blow all my money. (Car at the moment is bog stock. Car is also automatic. I kind of want it for drags and circuit. I know manual is better but my daily is manual I wanted something different)
Parts:
-Intercooler
-Turbo smart boost tee & Boost guage
-Nismo 555cc injectors
-Turbo gt3037 (do I need better?)
-Apexi power intake
-Walbro 255 L/PH fuel pump
-Low mount & dump pipe
-R33 S2 AFM (Or Z32?)
-Lightweight pully kit
-And a tune (what's best tune to get).
This car is a track car so not ever going to be road legal so dont mind if I have to straight pipe or what ever.
Would that be enough to make 350 HP at the wheels? Or would I need a few more upgrades. Money isnt too much of an issue but would rather keep it below 2-3k.
Cheers guys
https://www.sau.com.au/forums/topic/452592-r33-350-hp-build-need-help/
if you feel like saving money then just get a hypergear highflow done to your turbo.Those injectors and 18psi on petrol will make 350rw ponies easy.
Adaptronic ecu is much better than a nistune + Z32 afm
  • Like 1
Although 3k might be a little optimistic as around 2k for ecu and turbo, then it needs tune for around 60-1000 depending on where you go, then there's still a fmic kit and exhaust
Guess I'll be spending more money then haha
hyper gear high flow 850.
full 3 inch exhaust and dump, 2-400 drift sales.
injectors and fuel rail, again bargains to be had second hand, 2-800
tune 750
emanage blue 200 dollars or power fc 6-900
fuel pump 100 bucks.
e85.
will make your power figure easily.
  • Like 1
Have you played with the cam timing on the 32 ?
I see in your sig your 33 has a fair few bolt ons, what does the 32 have ?
I guess its your 32 that has 271kw ( if written respectively) plus the 32 GTR is 40kg heavier then the 33 GTS-t and there's fark all difference :/ , try getting the LCAs of the 32 cams to 110-108deg and see if there is still fark all difference :D
or try taking your motor thats been dialed in, and doing power runs at a further 20 degree intake retard, or a 20 degree advance, and see if there are any areas where you can from the extra advance, this will show you the use for vct
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
