Hi i am hoping for a bitof help here, went to change the rear brake pads/discs on my ARX and noticed a crack on the part pictured below.
Firstly, shit.
Secondly, what is it called so i can try and source the part from here or a wrecker.
Thirdly, is this part the same on all m35 models?
Thanks in advance!
Marty
https://www.sau.com.au/forums/topic/452623-what-is-this-part-called/
  On 12/01/2015 at 11:08 AM, Brick said:
Getting it welded is the best option, and if done right should be completely safe.
+1, common fault and a common repair, it will be as good as new. Don't forget to check the other side too.
  • Like 1
Well, I've currently got the car loaded so much that it's almost tucking tyre on stock suspension and wheels, and I'm about to hook up a loaded trailer (700kg or so, with 38kg pressure on the tow ball) and drive 200km over typically shitty, winding NZ roads, so I guess it's about to get a reasonable workout.
I kinda don't want to check it, because being a typical male, if I can't see it, it isn't there.
  • Like 2
