Difficult to offer correct advice unless you supply full engine details.
Generally speaking, you should run the max gap possible and for a stock engine with decent coil packs that's 1.1mm.
Likewise heat range would be 5 or 6 for a standard engine.
Once power is increased, you may find ageing coil packs can't keep up with the increased combustion pressures and the easy fix is to reduce plug gap.
Wouldn't suggest less than 0.8mm. If it takes a really close plug gap to avoid blowing out the spark you should be looking to new coil packs.
Heat range usually alters a range per 100hp increase over stock and it's pretty easy to have a 200hp increase.
Cold starts could become an issue with very high heat range plugs.
Make sure your IGN timing is correct while you're at it.
  • Like 1
For that hp GTR-Joey is on the money, but with your new coil packs I'd go for 1.0mm and see how she performs.
Check the shop actually sells you the BCPR plugs.
Often they'll offer BKR which is the same plug but built to ISO standards and protrudes 2.5mm shorter.
With them you need to give the spring conductor on the coil pack a bit of a tug to ensure it reaches the tip of the plug.
Grab some nickel thread anti-seize and apply a match head dob to the thread of each plug.
Tighten the plugs to the correct torque. Too loose and you'll see carbon up the threads of your old plugs. (the most common cause for stripping plug threads in alloy heads)
Blow the valley area clean with compressed air before you start removing things.
Remove/re-fit spark plugs one at a time.
So easy to drop an item down an open plug hole and suddenly that 5-minute job becomes very expensive.
  • Like 1
Thx Boys. Luckily for me my mechanic friend will be doing the work, but will fill him in with all these tips.
Also picked up a fuel filter, wondering how easy are they to change in the R32 GTR?
  • 3 months later...
I'm reading this topic and it's great but anti-seize
Common! !!!!
You got to think that if you putting that stuff on ya threads you start to isolate the plug from ground !!
Your coil is powering the plug but can't discharge it properly so the it searching for ground ...... Now it will find ground eventually where you did not coat the thread with. Now it can be a possibility of it electrode erode ya head meaning stripping ya threads slowly.
So not a good idea
But if you really find the need to put some lubrication on it... use graphite powder. This stuff is highly conductive and it's a dry lubricant.
Also do not use copper anti-seize coz it's reactive with alloys and normal nickel (silver ) is not good coz it's got lithium grease (non conducting)
Just my 2c
Jiffo I agree with your comment and great tips apart the Anti-seize ;)
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
