2 words about the datto...... F**KING HANDFUL
took me a bit to get used to it as it handles like a boat but after a little bit of advise from a friendly rotary driver I was starting to get the hang of slinging it sideways....
As Duncan has already said it needs a few things:
1. STIFF AND LOW suspension
2. Smaller steering wheel
3. MUCH tighter handbrake
4. New Seat
5. New Engine and 5 speed gearbox (pending compression test)
6. New Radiator
All in all I was fairly happy with the way it went throughout the day, the locked diff certainly provided some entertainment for the crowd watching at times :P
  • 1 month later...
mmm, ran it at the UAS dyno today, everything was OK but even the stickers couldn't get it the extra .3 rkwk it needed :(
BTW, does anyone know a good Datto suspension workshop in sydney?
Cheap rebuild - buy Z22 motor (cheap) use +2 oversize pistons , L20B head timing cover mild cam better carby and exhaust and bluebird 5 spd . I can't believe you didn't look for one with semi trailing arm IRS . With the 4 link you will never stop it doing the rear steer thing . H series diffs are a bastard to work on and very limited in suitable ratios . LSD's are rare and expensive . If it was me I'd have been paying the loan off on a cheap N/A S13 or R32 . Far more competitive standard and all the good bits fall in . Still for a project could be good .
you know, we expected to need a rebuild by now but the bloody thing hasn't died yet.
gee its nice how cheap parts are for older aus cars too....$50 for a secondhand engine, makes $6000 for an rb26 look pretty poor....100hp/$50 = 5c per hp versus 280hp/$6000 = $21.42 per hp :D
yeah the IRS would have been a better starting point...but this car was the right price....and we now have a *very* limited slip diff due to our good friend the mig welder :(
Stewart Wilkins knows his datto stuff, thats where i get my bits from...also try SSS automotive although i think they may have moved away from the older stuff now....
The recipe for a good torquey L series combo consists of(ive built one b4)......
  • L18 Block
  • Double counterweight crankshaft, I avoid using the single weight cranks.
  • L24 flywheel, lighter than the 4cyl ones and accepts the larger diameter clutch plate and pressure plate(i think Navara is lighter again, but dont quote me)
  • 720 4WD Clutch
  • L16 conrods, as they are 2.9mm longer than the L18 rods. This improves the rod ratio from 1.66 to 1.7, giving more bottom end torque. The standard datsun piston has a 2.9mm deep dish in the top. So by fitting L16 conrods and machining the piston flat, you end up with a zero deck height, flat top piston bottom end, that has a better rod ratio than the L20B (1.68).
  • 60 thou oversize pistons
  • Stanza SSS gbox...better ratios and reverse is directly above 1st making it ideal for a kana car.
    R 2 4
    1 3 5
You can take an L18 to 140thou over and use toyota pistons if u wish...they have massively thick bores.
Z22 + 2 = 2290cc which still revs reliably and uses cheap common L20B accessories ie buy bore bolt . The larger capacity engines make a broad usable torque curve which is needed for motor khana . If you want to spend more money the L Series head will go onto a Z24 block with a bit of work . KA24's are better again but use the SR20 bell housing pattern . It comes down to how much you wish to spend . If its not much just freshen up the L20B .
I forgot one thing, the L18 head has the best design combustion chambers of all the L series 4's.....the 200b has the largest port size.. you choose which one you want, but i'd go the L18 and port it out and fit the larger valves.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
