The satin finish on the lip looks great!
I've plastidipped the chromed plated grille on my NM35, and the finish has stood up far better than I ever expected.
It gets loads of freeway kilometres, and hasn't got a single mark or stonechip in over 6 months.
done f**k all on the car apart from driving it and being on holidays,
however the new leather boots finally arrived.
old ones were shagged out and even they were aftermarket.
found out, not surprisingly that almost all of the clips have broken underneath which hold the boot on
need to track down one which hasnt been broken...... bet thats not gonna be easy.
new boots on but with f**ked clips its just not going to sit right.
pmed :cheers:
clutch pedal started squeaking recently, wasnt the clutch pedal bracket so checked out the gearbox side and found out there is no rubber boot on the clutch fork pivot bit.
sprayed some lube on it and it has hushed down, but where would i get a rubber boot from, looks like i can just get it on over the clutch fork without taking much apart but can you get them new anywhere?
still been doing f**k all apart from doing the daily shit.
did however pop down to see Paul Pavlou motors who were nice enough to find a spot of free time and popped her on the Dyno to get a base power read out.
took the opportunity to bump the boost up till the engine was happy.
to be honest i was quite surprised at the power out put but more importantly the torque output! made bucket loads. and it feels like it too. pulls like a motherf**ker for a stock car.
10psi base run - 14 psi final run.
used a GFB bleed valve for now which holds the boost well, no drop or spike.
now i havn't tuned anything just bumped the boost up keeping an eye on the AFR which stayed happy, nice and safe.
Took it on the adelaide four six rotary cruse last night through the hills which gave me a good change to test it out properly and she pulls along nicely. also it shoots flames occasionally.... so the car behind me said :P
makes me want to get a haltech in there...
Edited by GH05T
  • Like 2
insignificant update of putting leds in the number plate lights, but jebus, how f**king dirty did these want to be.
has to use headlight polish to get through the shit.
also it turns out the red reverse light was some super hard to get off (and quite good quality) layover wrap stuff. so thats coming off.
  • Like 1
also need to sort out the annoying over tensioned timing belt noise. shits me at idle.
gonna replace obviously the timing belt and associated parts
would this be the cheapest option? if you have the hookup let me know ;)
is this the preferred option?
http://justjap.com/gates-racing-timing-belt-kit-nissan-rb-twin-cam-engines.html
Should i do the water pump as well?
yeah lets do the water pump too...
should i get an N! pump while im there? i think there just a better impeller blade design yeah? not like the n1 thermostat which f**ks with street driven cars?
Edited by GH05T
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
