still trying to work out the vin.
its not a nismo but comes with an amazing amount of nismo genuine parts. skirts, vents, lights, lips dash. which SEEM to have come standard.
even the wiperless rear window is vin confirmed.
but alas as far as i can confirm its not a ... vin confirmable special edition.
bnr32-002911
noone has so far been able to decode the last 3 vin digits properly though. fast has been no help without speaking jap.
Edited by GH05T
bnr32-002911
theres nothing to say that some bits could not have been fitted afterwards though?
you have to remember these cars arent anywhere near new and there has been up to 25 years of people messing with it. its a bit of a lucky dip on what you end up owning.
At the end of the day you have a nice car with some nice OEM parts.
very true. so far my lucky dip searching hasnt brought up any real scary things.
im more interested in the last 3 digits to simply know what they are, just too much conflicting info across different forums.
it seems the door skins are not original as my car (we think) came out with the heated mirrors but i have controller, but i have spare door trims which already suggests this.
how do i work out if the original heated mirrors are still attached, any easy way apart from taking the glass off and opening it all up to find the element? im assuming there will be extra wiring.
if so i will hunt down the proper switches, but to be honest i have so many other things to take care of and put money and time towards first.
still havnt done my timing belt or high idle
still need to work out how far to go with the paint respray
still need tires badly
STILL need to do my bushes.
holidays coming up :)
i have fixed a few issues on my alarm which includes reinstating the neutral switch so my remote start don't propel the car driver-less into a wall.
it seems my neutral switch is sticking in gear, where would i look to free this up, how would i go about freeing it up? is it simply a mechanical/ WD40 job or?
I found this diagram it shows the neutral switch in the side of the gearbox. I would remove it and check it with a multi meter.
Nice car BTW.
Hope to see you out in it for the Adelaide GTR cruises held monthly. Next one 1st March
ok so the nismo dash has been bugging me since i started cleaning the gtr.
the gauge lights have been replaced at some point but for some reason not all of them were replaced. so i have some yellow and some blueish white sections of the dials.
on top of that the clear plastic is really dirty. it cannot be cleaned as the old....what looks like condensation, has marked the plastic and is on the back/ inside of the plastic. so out they all come.
the bluish white dials are currently using these. which were probably all that was available back in the day. luckily now we have wide spread cluster LEDS :)
04e91eb1-6fdf-40d8-a2a1-61a181327086_zps
this is a good shot of how bad the plastic was... i can tell you, when you look at it everyday it really gets on your nerves.
also im amazed that the plastic just pops off these little clips and its out. no wonder the odos gets haircuts more than i do.
so i tried the usual windex and cleaners which did absolutely nothing
as i have owned a 34 before, i obviously had headlight polish, so gave it a good go and it came up crystal clear.
this is what it looks like now with the plastic back on..... soooo clear
compared to, how i got it.
now all bright and and even white with the new leds in.
honestly, i would feel uncomfortable if i pulled something apart and did not end up with a left over screw.
dfe9fdf4-2379-4ed6-ab1e-c255c1f6b23d_zps
Edited by GH05T
  • Like 5
Top work on the cluster
Ps. when I bought my 32GTR the previous owner had the biggest friggen elcheapo Tacho gauge with shift light screwed into the side top of the dash
Bloody fool
Edited by Sinista32
Hey mate. curious as too how your needles are so Bright. i know in all my R33s ive owned and ive put LEDS in all of them bright ones too. yet the dial needles seem to be dark as at night time and not illuminated like yours. any tips??? or do the r32 cluster have a led right on the needle?
got bored today so poped down to the shops and picked up some plastidip.
the (not so well) painted front lip dosnt look right to me but i still havnt decided fully if it should stay painted or if i should go back to the factory matt. thats what i love about plasti dip, dont like it its not permanent :)
unsure on the colour i picked up matt gunmetal grey which when sprayed looked like this, (tester spray)
miles off. so i went back to flat black.
ea32a6e6-8fa6-44bd-813e-35cff7d7ddda_zps
first coat filled imperfections less than i thought (being rubber) so i have gone several coats, as thick as it would let me without running. hopefully it will act as a sort of light stone protectant while its there.
Coat one..
anyway looks better imo, what do you think?
ill try to get a better photo in the morning.
Edited by GH05T
im also interested to see how it stands up to general road shit and more importantly, cleaning afterwards as its still a daily afterall.
bth if the matt look grows on me i will either get it painted or maby look at a cf option.
Personally I think cf is so over rated but you have to try different things to see how u actually like them and if they grow on you or not. I think slowmedown has the look of his gunmetal gtr right and from memory it's the factory finish. I actually like both the colour marched look and the factory finish/oem/raw finish. I think the best thing about not painting the lip is if or should I say when you do scratch it it's not obvious as dogs balls and doesn't catch you eye.
I'm fitting a gtr bar to my gtst and am going for the colour matched option to start with
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
