What exactly did you want to know?
Take a picture where the clutch lever comes out and of the thrust bearing, even the pressure plate if you have it.
If the slave was mounted behind the clutch lever (towards the rear of the box) its a pull type clutch, if its mounted on the engine side its a earlier push type.
Edited by GTRPSI
actually just to be difficult I'd say its probably a 33 gtr box which was converted to push (ie 32 type) because it does have both clutch mounting points on the bell housing.
But anyway, it doesn't really matter. They are all the same internally except for some parts in series 3 R33 GTR boxes. In any case the 32 and 33 series 1/2 parts are discontinued and you would have to fit 33 series 3 parts. They are all the same strength (ie very strong for a production box, but not unbreakable with enough power).
I don't know much about differences in the attessa pumps but can note that the plugs on it are not 32 style, they are 33 or later style.
  • Like 1
