Intake manifold gasket fixed, booked in to finish off the E85 tune next week...
Now just to reflash the wideband to read E85 properly, swap brake pads, install the catch can and do an oil change.
Giggity :D
  • Like 1
Boooooo :( That sucks, the cyls which killed plugs I'm guessing?
Yup
likely going to have to pull the head off to diagnose what went wrong
Couldn't get a refund and can't transfer the entry, and SAU dont do another round with circuit club this year. le sigh
Yup
Take your daily :P
Took the emo out to PI the other week, was feeling surprisingly good around the corners.
If I fixed up the brakes and put on some decent tyres it'd be a monster, and still completely stock :/
Still not as fun as the skyline to drive though...
  • Like 1
Yup
http://www.circuitclub.com.au/page/faq -> What is the cancellation Policy on my ticket?
Looks like they do allow cancellation / postponement in exchange for a Circuit Club Credit Code... I don't see why they would say No to this, then you could just do a different circuit club event later in the year...
I ended up getting a refund :)
See you guys in a few rounds!
Looks like I'm out also for this round, still waiting on parts :(
how did you go about getting that refund, just a simple email?
I'll be leaving at 4:45am (for a S.E. Meet point, I will swing by Burwood Highway / Springvale Road Dan Murphy's Carpark at that time if others are coming too...), then meeting a few others at Wallan BP Outbound (~5km past the "Wallan" exit on the Hume) at 6am.
Express your interest now, or I'll just drive straight there :P
  • Like 2
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
