Hi guys,
Here is an interesting one. I had the original spec wheels 225/45/18 & 245/45/18 on the before I upgraded them to a 19inch set-up (245/35/19 & 275/35/19). Recently I got a small cosmetic bend on the outer lip of the 19s and decided to put back my stock wheels.
Stock wheels go back on, and the traction control doesn't let the car accelerate and the SLIP light comes on. Car wont go more then 60-ish no matter how much the throttle is pressed. If I turn the traction control OFF, it is OK but I wasn't totally satisfied and went back to the 19s.
Any ideas on why this is happening and how to rectify it?
p.s. I had no issues when going to the 19inch wheels.
are you sure you put the 245s on the rear and not the front?
I swapped my wheels front/back to check if there were any clearance problems with 245 tyres on the front of my sedan and the VDC went nuts.
How long did you drive around with them on for? A couple of times what I have changed tyres size/profile dramatically and the it takes the VDC system 20 mins or so to learn, then it just turns the lights off and is all ok again.
Yeh I thought about that but I'm 100% sure they were on the correct ends.
Actually not long at all, maybe only 2-3 mins then back into the shop to get them changed back. How did you drive 20mins? It hardly let me accelerate?.....It seemed ok when I turned it off (VDC).
Yeah I heard something like that.
Yeah and a fewpeople have a problem when putting the car on the dino and it take a while for the car to set itself right again. Holding the VDC down for 10 sec might help.
Hi guys,
I think I know what the issue is...
You do not have the stock 18" tyre sizes fitted...
Standard 18" tyres are 225/50/18, not 225/45/18 on the front. With both ends being 45 profile on your car, there is a 3% difference between the front and rear wheels rotational speed and I belive that this is enough to trip the traction and stability control systems.
The fix would be to fit the correct 225/50/18 tyres on the front, or do what I did, and fit the same 245/45/18 tyres on the front rims. They do fit fine.
^^ Nah I had vastly different width wheels, tyres and type profile/rolling diameters from the rear for years - like I said previously, all you have to do is drive for 10-20mins or so and let the ECU figure out what is going on, and it all goes back to normal.
The stock sizes are 225/45/18 front and 245/45/18 rear. Even the tyre placard on mine shows this.
Same with the 19s. stock sizes are 225/40/19 front and 245/40/19 rear.
They are a staggered setup.. I think the 350Z might be the same??
Edited by sonicii
Ah sorry, my bad, I thought V36...
I guess the V35 has more robust handling of the diffrence in the wheel speed front to rear... I have seen this issue before with the V36s and it was the difference in tyre size that screwed the VDC system up..
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
