R32-25t is right. Cam gears, compression ratio, changing the engine capacity or putting smaller turbos on is what will increase response. Of course a good tune is always necessary but won't make the turbos smaller, I have -5's on a 2.6. 4500-5 k is where they hit full boost. An on tight corners an tracks I wish I had smaller turbos sometimes, as some corners 2nd gear is too Laggy you can drop it back to first but ur got 6000rpm n close to 400kw on tap which isn't really what u want either. Fast corners or straight lines -5's are great.
can you show me your logged afr numbers on your dyno sheet please then id like to see how your ign values look at the point of on boost.
all camshaft specs?
gears?
exhaust dia?
which injectors?
fuel?
plug type gap?
coilpacks?
is engine warn out most people wouldn't know!
easy to blame a turbo.
there are many factors.
all camshaft specs?
gears?
exhaust dia?
which injectors?
fuel?
plug type gap?
coilpacks?
In the fact that you cant take a blokes word who owns and tracks the setup in question for them being a bit big for a 2.6L. Then wanting to try pulling apart his setup to try justifying his response that's how ;) I'm sorry but the choon ain't gunna make the improvements in boost response like the breathing mods will!
  • Like 1
y not just trying to help him..and im sure others with more responsive -5 set ups will chime in with advice also what's wrong with that we're just here to share ideas and help each other out there are some very knowledgeable people on this forum in different areas for different reasons can't hurt
Edited by mr skidz
I don't understand what there is to argue about though? -7s and -9s spool up a lot earlier than -5s, that's a fact. Therefore -5s ARE LAGGIER. You're interpretation of "How much lag is too much lag", might vary greatly to someone elses in this thread. At the end of the day some people say -5s are amazing, but I'd say an equal amount say "-5s are too laggy for me". Most of the time because these people only drive theirs on weekends down to the shops.
While you are right that a tune can make a massive difference in response (in comparison to a SHIT tune). The size of the turbos still stop it from ever coming near the smaller turbos response time. I have driven, and continue to drive multiple different GTRs on a weekly basis, I will never recommend -5s to a customer with a STOCK motor. While they are more exciting on boost than the smaller turbos, you're not driving above 4500rpm for 99% of your driving.
I also don't want to have to blast the ears of people I overtake because I needed a louder exhaust to make close to 400kw for the street.
Oh the lols
People keep mentioning only driving to the shops on weekends and the -5s being to lagy only for them, that is where matters least, it's on the track that laggier turbos show the weakness
While you can drive it above a set rpm to keep it "on boost" that is only half the story, ever wonder why there are GTRs out there that run 13 second quarters at 140mph, it's because there is also lag between gears and/or if you have to pedal it then there is lag waiting for it to boost up again, this is also true for circuit for ever gear change and when come out of a corner and the back end tries to overtake the front and you have to get off the gas
Most people won't know enough or have enough experience to feel this
Also it has been mentioned about advancing or retarding the cams, this is where twin cams come into their own
What happens if you advance one and retard the other and vise versa
Please note there is no question mark as I'm not asking, I already know the answer
It was also mentioned tuning with EGTs, this is only truely beneficial for tuning if done with individual EGTs, one for each port
This I have never seen done on a true street GTR with factory mount turbos
I also think what Mick-O was saying is if you are taking the car to a half decant tuner and not trying to tune it yourself ( this applies to the average Joe and not people actually capable of tuning ) then taking it to a different tuner isn't going to make a world of difference to turbo lag where mechanical changes can, this also doesn't apply to power at given RPM range but where in the RPM range the turbos hit full boost
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
