R32-25t is right. Cam gears, compression ratio, changing the engine capacity or putting smaller turbos on is what will increase response. Of course a good tune is always necessary but won't make the turbos smaller, I have -5's on a 2.6. 4500-5 k is where they hit full boost. An on tight corners an tracks I wish I had smaller turbos sometimes, as some corners 2nd gear is too Laggy you can drop it back to first but ur got 6000rpm n close to 400kw on tap which isn't really what u want either. Fast corners or straight lines -5's are great.
can you show me your logged afr numbers on your dyno sheet please then id like to see how your ign values look at the point of on boost.
all camshaft specs?
gears?
exhaust dia?
which injectors?
fuel?
plug type gap?
coilpacks?
is engine warn out most people wouldn't know!
easy to blame a turbo.
there are many factors.
all camshaft specs?
gears?
exhaust dia?
which injectors?
fuel?
plug type gap?
coilpacks?
In the fact that you cant take a blokes word who owns and tracks the setup in question for them being a bit big for a 2.6L. Then wanting to try pulling apart his setup to try justifying his response that's how ;) I'm sorry but the choon ain't gunna make the improvements in boost response like the breathing mods will!
  • Like 1
y not just trying to help him..and im sure others with more responsive -5 set ups will chime in with advice also what's wrong with that we're just here to share ideas and help each other out there are some very knowledgeable people on this forum in different areas for different reasons can't hurt
Edited by mr skidz
I don't understand what there is to argue about though? -7s and -9s spool up a lot earlier than -5s, that's a fact. Therefore -5s ARE LAGGIER. You're interpretation of "How much lag is too much lag", might vary greatly to someone elses in this thread. At the end of the day some people say -5s are amazing, but I'd say an equal amount say "-5s are too laggy for me". Most of the time because these people only drive theirs on weekends down to the shops.
While you are right that a tune can make a massive difference in response (in comparison to a SHIT tune). The size of the turbos still stop it from ever coming near the smaller turbos response time. I have driven, and continue to drive multiple different GTRs on a weekly basis, I will never recommend -5s to a customer with a STOCK motor. While they are more exciting on boost than the smaller turbos, you're not driving above 4500rpm for 99% of your driving.
I also don't want to have to blast the ears of people I overtake because I needed a louder exhaust to make close to 400kw for the street.
Oh the lols
People keep mentioning only driving to the shops on weekends and the -5s being to lagy only for them, that is where matters least, it's on the track that laggier turbos show the weakness
While you can drive it above a set rpm to keep it "on boost" that is only half the story, ever wonder why there are GTRs out there that run 13 second quarters at 140mph, it's because there is also lag between gears and/or if you have to pedal it then there is lag waiting for it to boost up again, this is also true for circuit for ever gear change and when come out of a corner and the back end tries to overtake the front and you have to get off the gas
Most people won't know enough or have enough experience to feel this
Also it has been mentioned about advancing or retarding the cams, this is where twin cams come into their own
What happens if you advance one and retard the other and vise versa
Please note there is no question mark as I'm not asking, I already know the answer
It was also mentioned tuning with EGTs, this is only truely beneficial for tuning if done with individual EGTs, one for each port
This I have never seen done on a true street GTR with factory mount turbos
I also think what Mick-O was saying is if you are taking the car to a half decant tuner and not trying to tune it yourself ( this applies to the average Joe and not people actually capable of tuning ) then taking it to a different tuner isn't going to make a world of difference to turbo lag where mechanical changes can, this also doesn't apply to power at given RPM range but where in the RPM range the turbos hit full boost
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
