The most important aspects that the greddy intake kit addresses are the cold side merge before the FMIC, and the tendancy of stock intake (black rubber) to partially collapse and restrict intake.
The intake path is also much smoother for airflow.
Strangely the fixing the merge reduces turbo shuffle but on AFM setups the smoother intake of the hardipe kit has been know to increase it!
If you have a 33 or 34 I would personally recommend keeping the stock airbox, and either modding the stock twin turbo pipe or lashing out on the nismo item.
Intake to airbox can be firmed up be KTS hardpipe kit or one of the reinforced silicon pipes floating around.
For me on my 32, I scored the greddy kit cheap second hand and because I was changing to MAP I could ditch the poxy foam filters for some (larger) quality K&N items.
For the average punter I don't think there's any noticable power/response changes, but intake noise is much more noticeable as is OEM recirc/bov... this is a pro/con depending on your preference.
  • Like 1
  • 3 months later...
Update:
Installed Tomei dumps this week ( Bought HPI dumps but couldn't fit on my R34 Gt-R, 15mm too short, would only fit R32/R33 apparently) and "hi flowed" the twin cats of my Nismo exhaust.
Result:
Couldn't tell that much difference, low to mid range was still laggy like before, not much untill 5k rpm. The pick up might be slightly better but can't say for sure as I've only driven it for a short while.
Best thing gained it now shoots little flames on soft limiter cut. Will be installing intercooler hard pipes next week, hopefully this will make more of a difference.
Update:
Result:
twin cats?
why 2 of them?
I don't want the one I got already lol
who tuned it and what they say it could be
twin cats?
why 2 of them?
Twin cats because it's a Nismo exhaust twin 2.5 inch into 3, still saving up for a bigger exhaust, so this will do for now. Car was previously tuned by JEM and will be on the dyno soon once all the parts are in so hopefully a tune will fix things up a little.
Doubtless been asked and answered but what boost controller do you have. Need to be sure the wastegates are shut unless you need them to be otherwise.
Boost controller are profec B II, not too sure how too adjust it, so gonna leave it to the tuner.
Hpi dumps not fitting is news to me. I bought some that were originally on a 33GTR, bolted straight up to my 34GTR setup (GTX2860's now -5's) no problem.
You sure they didn't try to fit them back to front lol?! as they are different for front and rear.
Shit son, haven't heard from you for a while
  • 3 weeks later...
Bought it from just jap, even they didn't belive me. But putting stock next to HPI and Tomei you can see that HPI was a bit shorter, unsure why, so they happily swap it for me.
  • 1 month later...
Update: Car has been tuned and dynoed.
First run: With only thing changed to the car being tomei dumps and 'high flow' cats. Not much difference at low and high revs, made extra 4 kw at peak, this could be due to change in temp or other variables. But did gain some mid range torque and peak boost happening maybe a bit earlier, nothing spectacular but the dumps and cats did make a small difference.
Second run: Now installed with Nismo hard pipe and Nismo 100mm intercooler, 1000cc injectors, 450L fuel pump. Peak power gained of 17kw to 313kw atw at same 19psi. More power and torque across the rev range, biggest difference is peak boost happens at 4550 rpm instead of 5000 rpm.
Drive: Car definitely feels more more responsive and pulls harder, response is still a bit slow compared to stock turbos but it's much better than before.
Cost: $1000 for every 100rpm of response or $300 for every kw gained, f expensive.
Conclusion: I think we are half way there, next on the list will be bigger exhaust and turbo inlet pipes.
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
