Hi Guys,
i just got my first Skyline, and this is my first post on this site,
big thanks to all you guys, i did alot of reading on this site before i decided to do this build
This is the Car
Its a 1991 R32 Gtr
grabbed it of ebay from a retired policeman in Newcastle
its not running, blown turbos,
we towed it back to Sydney and are now in the process of bringing it back to life
https://www.sau.com.au/forums/topic/453974-r32-build-log-my-first-skyline/
Now comes the fun part
im keen on a pretty involved rebuild
and i wanted to get some advice
the build list (so far)
rub back and respray $3500
Rb30 Bottom End $500
RB34 Stroker kit (pistons crank and rods) $5600
borg warner efr 9180 Turbo $3700
Brian Crower BC0230 Valve Springs $500
Hks Camshaft 272 10.2 LIFT STEP 2 $1000
Headwork port and polish $1500
GFB Wastegate $700
ebay single turbo exhaust manifold $700
4 inch turbo back exhuast $1800
Haltech plug in ECU and flex module $2500
im still unsure what fuel setup to install
and i know there will be many many many other parts i will need (happy for any advice)
im not chasing any particular power figures
i just want a good strong car that will be "reliable"
any help will be appreciated
Saw this on ebay. Congrats on the purchase. Looks like a good base to start with.
That's a rare colour so I'm told.
"The factory Pearl Blue is a special order on the V-specs (according to an independent site, only around 300 ever made"
Will it be a period correct resto or balls out build? Either way, looking forward to the end product
definitely like the blue paint and would love to keep it,
i just need to track down the colour,
as for the restore or balls to the wall,
im not chasing a actual power figure, but i want to build a very capable street racer,
low lag, lots of power, (essentially the impossible dream)
i rather have 700 HP and less lag instead of 1000 hp and a lag monster
has anyone used this turbo before, ive been told with the 3.4L engine it should be making 20psi by 3000rpm,
and for the manifold, i just checked for a steam pipe one, that looks really good, thanks for the tip
The Borg warners are fantastic from what i have heard. My tuner has been trying to convince me for years.
I would just make sure you do all the reading in and actually decide on a figure you want. Will help with the overall build.
big thanks Anfanee
i honestly did not know what to do with the gearbox, and ive never seen that gearset before
and that set is really good (smooth and quiet) from what im told, i dont like the idea of a "dog box" or a sequential
i want a regular manual car, that i can drive every day if i want to, no crunching and jerking
so with your help i quickly found this link, the guy from just jap says the gears will hold 800hp ish
http://justjap.com/os-giken-cross-gear-set-nissan-bnr32.html
but i need to get a working R33 GTR gearbox to install the parts in , thats where im stuck
i rang around, there are none that i could find 2nd hand
the only other option i have is to get a R34 GTR gearbox and hope it holds,
but im thinking the gearset might be stronger,
anyone have any experience
... $60,000 build. If you think you will finish it for much less than that your kidding yourself.
...20-25k on a 3.4 stroker engine and bolt on's and you're going to cheap out on a manifold and gate?
Set some goals, set out a budget and build something achievable for you.... a 60% car that runs is a lot more fun than a 99% car that's in bits still.
Cheers
J.
By the way you have written your opening posts, your running head first into it (like we all do).... and I have impressed upon you the scope of a build (in dollars, not to mention the time) you are talking about.
What you have said is somewhat contradictory though... why use obviously cheap and inferior parts for a 'reliable' build, why go a full tilt 3.4lt build for a 'strong car' ... why choose a 1000hp capable turbo that IS going to be laggy- when you're stating '700hp and less lag'?
... so I get to my last comment. Have a little think about what you want out of the car, do the research and choose components based on what you out of your car (as best as you can afford) within reason.
Gearbox... again comes down to what your actual goals are, what you intend to use the car for and what your budget is.
If you want a fast, reliable, easy street car that is very capable on the track... look at an r34 GTR conversion with the stock r32 GTR gearing. If you want to drag race, throw a 2 speed power glide in it.
I do like the colour... have fun with it, because building a GTR is a rewarding experience.
Cheers
J.
GFB Wastegate $700
That's $22,000 plus the price of the car............
I hope you have more success than I do.
I always do my arse on these type of builds.
I genuinely wish you good luck.
Bob.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
