Hi All
I got hold of a manufacture who can EAST Bear style bodykit in fiberglass. thinking of a group buy.
Price is $1700/kit pickup if i can get 5 sets on a group buy.. or freight to interstate at your cost.
Price includes:
Front bar
Rear Bar
Side Skirt
Bonnet.
Carbon fiber face bonnet add $300 extra.
they are NOT made in japan hence much lower price. however quality is great as i have purchase other body parts from them.
attached with a picture of what their quality is like.
please PM or contact me through my phone if you are interested.
0433289998
Joe
picup from mill park. right now have 2 people including myself keen on the kit.
need 3 more:)
if people want just parts. perhaps can order a kit and split
I will list down as follow:
ordered
Bonnet: $550 2 Newbie 34 - -
Front bar $450 2 - - -
Rear Bar: $370 2 - - -
Side skirts: $320 2 - - -
Great Kit!! comon people:)
I've spoken to you via sms.
I'll put the deposit when you have 4 people interested so I know its going through.
I'm 100% serious about this order, definitely count me.
Edited by baby34
yes will fit series 2 r34 skyline no problems.
you dont need GTR hinges.
Will be placing order by end of coming week.
if you are interested please arrange 30% deposit and you will see the kit mid MAY!
  • 4 weeks later...
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
