Hi all I have a r32 gtr im just not getting the time to do, the car was complete till cylinder 6 let go I bought a low k replacement motor to put in added some parts but I haven't had the time to put it back in
so im looking to sell this off either sell motor and box as a package and rolling shell separate
or the lot you just have to assemble it
price is $8000 for the lot pretty frim on the price
as for shell separate to motor I will wait and see I would like the lot to sell together
car is located in noosa on the sunshine coast
best to phone or text on 0416 356 098 ............if I don't answer leave a message or text and I will call you back when I get a chance... phone s on silent most of the time
Details
Motor was out of a 94 vspec 2 which had gone backwards into a wall so it will be a late model crank (long oil pump drive)
has nismo le mans turbos
xforce dumps
tomie sump baffle
aftermarket y pipes
3ince mild steel exhaust
os giken twinplate which has ok giken rebuild kit for it and fly wheel has been machined
the shell is complete all the parts are there, but the bonet front bar and intercool all has ben removed to make getting motor in and out easier
walbro intake pump
tien coilovers the electronic dampening ones has a thing in the cab so you can adjust on the move
all the interior is there minus a cd player
there will be things I have forgotten but its all there I just do not have time to work on it due to have 2 kids and renovating the house I would rather see it go to someone who can get it going again sooner than I can
the pick is when it was all togeather I can get pics as it sits now but not much has change
Edited by daz32
Check it out for me when you head past the Gold Coast Plattsy, looks like a great deal, but it's just too far away for me to check out.
Good luck with the sale Darren.
no swap needed just drop the new engine in old is already out and you got a gtr for 8gs with some light mods 2g more put a aftermarket ecu on and should be able to get some decent power aswell
  • 3 weeks later...
Sorry for the late reply I have been away working
I would prefer to sell it as a complete car for the moment but if I do part it ill let you know
it is a late 90 model
and the gearbox isn't in the car currently
Thanks Daz
  • 3 weeks later...
hey guys this is still for sale next time im home is between the 9th and the 19th of may if you want to come inspect the car or want pictures of it send me a text or private message with your email and I can forward them through
Here are a couple pics as it sits now
Edited by daz32
  • 3 weeks later...
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
