Hey!
My HID headlights have started to randomly turn off while driving.
It will usually flicker on/off for a second before staying off. They turn straight back on again after turning the lights on and off, but will start doing it again shortly after. Its not both lights in unison either. One goes... then the other.
It appears to be triggered by G-forces/movement as it often flicks off when i make a sharp turn or go over minor bumps in the road.
Anyone know what could be causing this or of a good auto-electrician in the Brisbane area?
I can't find anything on the forums except someone in Sydney with the same issue on a V35 that had zero responses.
Thanks in advance for any help!
Sounds like it's the lamps. Have you tried another lamp? Turning it off and back on makes the ballast kickstart the lamp with an initial high voltage discharge. It's more likely your lamps would both go out so close together rather than your ballasts.
Replace the lamps.
Make sure you get colour matched ones
I had the same issue with my Stagea running Xennons, and they would both go out when driving at night. Fixed by replacing the old ones with new ones.
I guess we don't know how it is. :yucky:
Actually, while it's fresh in my mind, not that I need to buy any now but I'm a little disappointed with the high beam performance of these headlights. Even my BA lights up a street better with its high beams. I suppose that's more of a limitation of the headlight mechanism but as far as squeezing the most performance out of the lamps themselves, which ones do you recommend Chris?
Edited by The Max
I have seen LED lights in these. dont seem to be that bad.
HID bulbs pulse when they need to be replaced. They often don't "burn out" perse, but the chemical reaction inside the bulb reaches its limit, and needs to turn off to rewind the process. Replace bulb, It will be fine. Note: don't touch bulb with fingers, or it will go pop.
What high beam halogens? I thought the headlight mechanism just repositions the HID bulbs up a little higher? Hence my question. I'm seeking the best performing bulb for the job.
Ahh the G37/V36 are bi-xenon. The cutoff shield drops when you high beam.
Look at the link I sent you, there are some 'higher output' bulbs but they cost a pretty penny. I think you'll be happy with the Philips Xtreme (since it's closer to 5000K than the Osram Night Breakers).
Yes, good quality (genuine) bulbs are expensive. I've been through $150+ worth of ebay xenon bulbs and can tell you to go genuine from the get go.
One seller sent me 3 4300K bulbs, all different shades of white/yellow. What a waste of money!
To add, switching from ebay to Genuine Philips D2S gave a very noticeable improvement in light (colour, brightness, more evenly spread beam). Same projector/headlight.
That's why I'm advising to go genuine, I've already been though the shit so you don't have to!
Exactly why I asked. :)
I can't remember what my V36 came with off the boat but I'm fairly certain they were Osram bulbs. Anyway, when the time comes, I'll seek out the Philips ones.
I replaced the D2S bulbs in my 5GEN Liberty last night (have to get to the headlight via wheel well, shitty clips makes life difficult). Lights were so dim I couldn't see at night, the driving lights were brighter (country car so assuming lights were on all the time).
Chucked those Philips D2S replacement bulbs in = can see now.
So which ones of the bulbs did u buy? my stock ones on the v36 are not bright enough imo...
I thought he mentioned that in the last line of his last post?
uumm yeah he mentioned its philips but that brand has more than one type of bulb...just wanna know which has most output so i can spend my money wisely... :)
See his post in #12 above. Philips Xtreme.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
