re34perGTT Posted March 21, 2015 Share Posted March 21, 2015 Hi all, I'm going to be upgrading my auto r34 set up and I'm going to install some new gauges. What do people think about prosport gauges ? Also to install the boost gauge can I use any of the factory wires/ connections ? Lastly does an engine oil temp gauge work for trans temp ?? I can't find any trans temp ones so I was thinking about using an oil gauge and sensor for it ? Cheers guys Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/ Share on other sites More sharing options...
89CAL Posted March 21, 2015 Share Posted March 21, 2015 Oil is oil. Temp gauge will be fine What do you mean can you use the factory wires? Gauge comes with a harness, connect to switched power, earth etc Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501147 Share on other sites More sharing options...
scotty nm35 Posted March 21, 2015 Share Posted March 21, 2015 Oil gauge is perfect. I run a Prosport exhaust temp probe in the manifold, works perfectly. Just follow the instructions to turn the damn beep warning off. Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501149 Share on other sites More sharing options...
re34perGTT Posted March 21, 2015 Author Share Posted March 21, 2015 Cheers guys, was just a little unsure. Also oil temp sensor will work yeah ? Also do I have to run new sensors for the boost gauge and normal engine oil gauge to work or can I tap into anything from the factory set up to save some time ? Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501153 Share on other sites More sharing options...
scotty nm35 Posted March 21, 2015 Share Posted March 21, 2015 Good chance the sensors will be different resistance, you need to put the prosport sensors in for the gauge to be accurate. Do you have an oil cooler? I run mine in the hoses, same with the auto temp sensor. Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501158 Share on other sites More sharing options...
re34perGTT Posted March 21, 2015 Author Share Posted March 21, 2015 Yeah good point. And I'm buying a bigger trans oil cooler http://m.supercheapauto.com.au/Product/Davies-Craig-Hydra-Cool-Transmission-Oil-Cooler-8-Cylinder-Universal/125648 and I'll run the sensor after it before it re enters the transmission but the engine cooling is stock Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501164 Share on other sites More sharing options...
89CAL Posted March 21, 2015 Share Posted March 21, 2015 Better idea to run it in the lines to the cooler so you get an idea of how hot the trans is. Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501220 Share on other sites More sharing options...
re34perGTT Posted March 22, 2015 Author Share Posted March 22, 2015 So run it straight after it leaves the tranny ? Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501306 Share on other sites More sharing options...
89CAL Posted March 22, 2015 Share Posted March 22, 2015 Basically. Think about it this way (im going to exagerate alot here). If the oil coming out of the trans is 200 degres, and the oil going into the trans is 50 degrees, which would you rather know about? Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501310 Share on other sites More sharing options...
re34perGTT Posted March 22, 2015 Author Share Posted March 22, 2015 Yeah good point, cheers for the help guys Link to comment https://www.sau.com.au/forums/topic/454990-boost-gauge-and-trans-temp-oil-gauge/#findComment-7501496 Share on other sites More sharing options...
